Transmission Fluid Change
Old Feb 6, 2017 | 11:43 PM
darrenH's Avatar
9th Gear
Hi Everyone, I have a question about my RDX 2013 AWD transmission Fluid.I did some search which I found out two brands of transmission fluid seems reliable and fit for the car, but I dont know which one is better or any other suggest.
One is AMSOIL Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid:
The other is Mobil 1 Synthetic ATF
https://mobiloil.com/en/automatic-tr.../synthetic-atf
The Price is $160 vs $120 (case of 12). I would like to do is 3X3 flush.
I would like to hear your advise and suggestion. I am not very familiar with fluid.
Thank you very much!!!!!!!!
Old Feb 7, 2017 | 06:27 AM
I would stick with OEM...if you are not very familiar with fluid, why deviate away from stock??
Old Feb 7, 2017 | 07:49 AM
darrenH's Avatar
9th Gear
Hi Justnspace,
Thank you very much for your answer!!! It is very hard to find OME in the market.. I ask Acura Dealer, they only do drain/fill without flushing. So I would go to somewhere else which is also transmission professional and they doesnt offer the OME fluid but the replacement. That is why I post the questions which I can tell them which they should order and change into my car.
Thanks again for your time
Old Feb 7, 2017 | 07:58 AM
here's the thing. when flushing, you dont need to do the 3x3...
flushing involves a pump that removes ALL of the fluid at one time.
the dealer has the correct idea of draining and filling 3x3.
the automatic has clutch packs that HOLD fluid when you remove the bolt...
so, in order to remove the ALL of the old fluid, you will need to do 3x3 drain and fill.
In My Honest Opinion, I would go to the dealer and get the drain and fill.
you are risking your transmission if you do a FLUSH
Old Feb 7, 2017 | 08:54 AM
Brown13's Avatar
Here is Your source for Acura fluid: 08200-9008A | Acura Automatic Transmission Fluid (ATF-DW1) - Bernardi Parts
Old Feb 7, 2017 | 11:51 AM
darrenH's Avatar
9th Gear
Thank you for your adviser. But Acura dealer only do is single drain and fill not 3X3..If I insist, they will charge me more about $270. I think I could ask the outsider do 3X3 instead of flush which is more cheaper. $80 for labor fee and about $90 for case of 12 Acura Fluid.
So what do you think?
I'm very appreciate your help!
Old Feb 7, 2017 | 11:52 AM
darrenH's Avatar
9th Gear
Originally Posted by Brown13
Thanks Brown 13!!
Old Feb 7, 2017 | 11:55 AM
darrenH's Avatar
9th Gear
By the way the store is AAMCO which is national-wise company. It is reliable or you insist to go to the Acura Dealer.
Old Feb 7, 2017 | 12:04 PM
it is NOT advisable to use a machine to flush the fluid
Old Feb 7, 2017 | 12:08 PM
Don't flush
x2
drain and refill.
Old Apr 11, 2017 | 03:07 PM
Acc20yrs's Avatar
has anyone changed this filter on a tranny service?
Attached Thumbnails Transmission Fluid Change-rdx-trans-filter.jpg   Transmission Fluid Change-rdx-trans-filter-2.jpg
Old Apr 12, 2017 | 05:57 PM
jim_c's Avatar
I found that the Honda dealer charged more than a dollar per liter less than the Acura dealer, for the same ATF fluid.
