Guess the Part?!?!
Old May 31, 2026 | 02:45 PM
D-DubJr's Avatar
Question Guess the Part?!?!
Good Day RDXers!
Just did trans fluid, transfer case oil and rear diff fluid on our '15 RDX. In changing the transfer case oil, I had the dickens trying to get the 3/8 socket in the fill plug. The fill and drain plugs were rusted and tho I prevailed, direct access to the fill plug (to force an extension into the hole) was blocked by this part:
Engine Automotive Fuel System Nut Automotive Exhaust Fastener
This is a similar MDX image I grabbed from another post on here.
Mine is covered in oil - see actual pics from underneath, looking up:
Fastener Automotive Fuel System Pipe
Fastener
For orientation, the oil pan is to the right of the exhaust pipe.
Any idea what this part is and what it protects? It looks like there is a hose underneath it; but I didn't want to remove the cover and take a chance without know what I might find and might need.
I believe the dealer overfilled on my "free" oil change. This leak wasn't there previously.
Thanks!
Old May 31, 2026 | 04:52 PM
altair47's Avatar
That is the metal shield for the crankshaft position sensor; the leak is most likely coming from the O-ring on the rear main seal housing.
Old Jun 2, 2026 | 09:16 AM
D-DubJr's Avatar
Thanks. Just to clarify, do you mean the small section (yellow) or the actual seal (green)?
Old Jun 2, 2026 | 08:14 PM
altair47's Avatar
The actual rear main seal is green, but on these engines, the yellow O-ring is almost always the first to start leaking. Because it is located within the oil pressure passage—just like the oil pump gasket..
jbnyc
1G RDX Problems & Fixes
May 6, 2023 06:37 PM
737 Jock
1G RDX DIY & FAQ
33
Nov 16, 2020 04:51 PM
Trugr8ns
Mar 20, 2020 10:57 PM
hdp203_RENAMED
Jul 28, 2012 10:40 AM
rich9
Jun 16, 2012 12:32 AM
