2017 rdx vled interior
after searching this site and various on-line vendors, ordered these leds from vled.
few internet vendors were some what clueless as to type/quantity rdx required.
vled was the only site i was able to navigate easily and assisted without any difficulty.
with 10% discount total delivered $64.80
here are # numbers if anyone needs it.
@1 #WH-569 dome rear seat (#3175) 5500k white
@4 #WH-585 vanity (#vanity) 5500k white
@2 #WH-593 front door (#194) 5500k long life
@2 #WH-601 rear hatch (#194) 5500k 360* long life
@1 #WH-625 glove box (#74) 5500k 360* long life
(was bit thick, i'll try later when i have time or if unable, contact vled.)
I go with VLEDS. Pricey but quality. I've been using VLEDS LEDs for over 10 years.
I went with 5K LEDs in dome, cargo, doors.
I didn't bother with a vanity light and glove box change.
Just did fog light bulbs with VLEDS H11's.
The 3175 is thick but I didn't have a problem installing it.
I'll probably do the license plate bulbs but VLEDS choices are too bright for my taste.
If the stock license plate bulbs face down, then VLEDS has one LED bulbs that would work for me.
2017 rdx base with vled 5500k
stock front door w/o lens
vled w/lens
stock w/lens
vled w/lens
vled night
stock vanity
stock vs vled
vled
stock vs vled hatch
vled @8pm
vled @8pm
vled @ 8pm
vled on @1 @8pm
vled off @ 8pm
stock rear seat/dome
vled dome
vled dome from outside trunk @8pm
vled dome @8pm
you're welcome, i've benefited a lot from this forum. such as saccucci honda care, rockauto, front, rear, and cargo mats, deck cover,
front brake issue, rear hatch manual opening...
i'll post successful DYI's and when i fail miserably (often) , i'll still post so that hopefully
others can learn or have a good laugh.
Looks great, by the way.
Appreciate the insight.
insert tool and lift up slowly and with other hand assist from inner bottom edge of lens. to close - insert top first and press bottom
flipped side ways to reduce brightness
left (side way facing) right (forward facing)
insert tool back and corner area gently as you wiggle (slowly)
put two fingers at bottom and pull up while pulling it outwards gently or use tool while pulling
view pic at tabs before opening
pull down with hands and/or use tool to locate gap at corner area to assist
start, please view pics first.
visor light - use small thin blade screwdriver or similar tool and gently pry from bottom opening tab and assist with your fingers (gently).
"i turned the bulbs side ways to lessen the brightness, it was blinding at 5500k."
depending on brand, i had to flip it over when it didn't lite up.
bottom door - first look under neath and locate small opening. use two fingers and apply very light pressure upward and pull out at the same time.
or use screwdriver with it (carefully, don't force it!).
rear seat dome light - insert screwdriver back of light cover corner area and gently wiggle s/driver in and pry it off slowly!
lift gate - use two hands and gently squeeze downwards (gentle pressure) or use screwdriver to locate small opening to access at the gap.
gatrhumpy
Sep 25, 2025 11:00 AM
cruiserchuck
Sep 11, 2016 05:28 PM
vietxquangstah
Jun 5, 2014 10:25 PM
