2017 RDX engine oil dipstick
Old Aug 12, 2019 | 11:14 AM
Sounder93's Avatar
I've searched this website and online otherwise, I can't find the answer to the following question. What volume of oil is represented by the cross hatched area of the engine oil dipstick?
Old Aug 12, 2019 | 12:17 PM
egads's Avatar
Between the two lines? One quart.
Old Aug 12, 2019 | 01:56 PM
Sounder93's Avatar
I checked the oil the morning after a dealership oil change, it registered about 1/4 of the way up into the cross hatched area. I added about .65 qt. and the level on the dipstick is now above the cross hatched area. The letters RCA show above the full level, after adding the oil the level is at the top of the C. I've mostly driven GM vehicles in the past, I believe 1 qt was the volume represented by the cross hatched section on all of them. Seems not to be the case for my RDX.
Old Aug 12, 2019 | 02:52 PM
Mo_Green's Avatar
The correct level is at the top of the cross hatch. People always...always check the level before even starting your vehicle when a stranger changes changes your oil.
If you paid sopmeone a fortune for an oil change you'd expect it filled.
tatertot3381
Oct 31, 2015 07:22 AM
gcook
Apr 2, 2011 11:11 PM
owen8863
Apr 10, 2010 05:10 PM
stejus
Sep 15, 2003 05:26 AM
