Reboot (?) Fixes Glitch
Old Apr 13, 2014 | 08:56 AM
Texdriver's Avatar
Took our RDX in for normal 5000 mi. servicing. Dealer replaced battery because he said it was going bad.
Got the car back and needed to reset clock, OK, but for some reason the memory seat settings would not hold. Followed all instructions, but nothing. So I went thru the Custom Settings to see if maybe something got changed, no.
Finally, the last setting in the Custom Setting area is Default all. So I figured try it. And that solved the memory seat setting issue. Kind of like a reboot on a malfunctioning computer.
So I just want to pass along this simple possible fix if you are having some setting issues which can't be solved by following the normal instructions in the manual.
Old Jun 10, 2014 | 04:37 PM
velanderjd's Avatar
Thanks, had the prob & this helps
Mike734
Dec 10, 2021 01:25 PM
SidhuSaaB
May 30, 2020 12:40 AM
thegipper
Sep 28, 2015 01:01 PM
h22lude
Sep 27, 2015 06:22 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
