Reboot (?) Fixes Glitch
Took our RDX in for normal 5000 mi. servicing. Dealer replaced battery because he said it was going bad.
Got the car back and needed to reset clock, OK, but for some reason the memory seat settings would not hold. Followed all instructions, but nothing. So I went thru the Custom Settings to see if maybe something got changed, no.
Finally, the last setting in the Custom Setting area is Default all. So I figured try it. And that solved the memory seat setting issue. Kind of like a reboot on a malfunctioning computer.
So I just want to pass along this simple possible fix if you are having some setting issues which can't be solved by following the normal instructions in the manual.
SidhuSaaB
May 30, 2020 12:40 AM
