Bluetooth pairing code ?
Old Sep 21, 2012 | 09:02 AM
kgbagent's Avatar
Trying to re Pair my iPhone 4 (after removing the bluetooth profile on the phone) and no pairing code will work. I've tried the factory defaults, and the one I thought I had used at the dealer when I bought the RDX. Is there a way to display or change the bluetooth paring code? It does not show on the screen when pairing, nor announces it. I have a 2013 RDX AWD non-tech.
Old Sep 21, 2012 | 10:06 AM
BlackDogRDX's Avatar
Did you try 0000? That's the default. Otherwise you can go into the phone setup menu, connection, pairing code, select fixed, and enter a new one.
This is from the manual not from personal experience so apologies if it doesn't work.
Old Sep 21, 2012 | 10:10 AM
kgbagent's Avatar
0000 wasn't working. However, I did just bypass the auto prompt to pair, then went into the menu as you mentioned. I then selected add new phone even though mine was already listed and I was able to pair with 0000. Getting to the main phone menu was the key to getting it solved. Thanks.
Jamus22
Jun 11, 2023 10:08 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SUPRMN84
Oct 7, 2015 09:46 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
