6 ohm tweeters in front door - 2016 RDX Tech
I took the little panel that housed the tweeter off and the back of the tweeter says it’s 6 ohms. Has anyone else seen this? How do you replace the tweeter properly? Is there a 6 ohm replacement?
4 ohm tweeters will draw more power from the amp, but as long as you're not blasting your music at full volume, they will work just fine and not damage the amp.
desper
May 7, 2007 06:55 PM
DerrickM
Feb 5, 2005 12:20 AM
Napsoner
Sep 13, 2004 10:35 AM
