6 ohm tweeters in front door - 2016 RDX Tech
I took the little panel that housed the tweeter off and the back of the tweeter says it’s 6 ohms. Has anyone else seen this? How do you replace the tweeter properly? Is there a 6 ohm replacement?
Originally Posted by Juxagent
(Post 16265248)
Metal dome tweeters run around this range so they don't overpower the rest of your speakers due to their "bright" characteristics. A 4-ohm silk/textile tweeter should work fine and not be so overwhelming.
Good to know - thank you! I have some really nice 4-ohm silk dome tweeters I’ll try out then. |
