2016 RDX advance radio
Old Sep 22, 2015 | 06:22 AM
Puma Jim's Avatar
Had the vehicle since July. Every once in a while after starting I notice all my preset radio stations show different stations or no stations at all. It will stay like that until I shut off vehicle and restart. I read owners manual and found nothing. Anyone know any thing about this?
Old Sep 22, 2015 | 06:39 AM
RDX-Rick's Avatar
Mine does the same thing occasionally when first starting the engine. Sometimes it just displays random alpha numeric characters for the station names.
Often the display will return to normal by itself if I just wait for 1/2 minute, or if I switch to a different audio source, and then return to the radio it will also return to normal.
Old Sep 22, 2015 | 03:29 PM
Desert Ridge's Avatar
Mine has done it once. When it did it, the rear lift-gate was also open (of it's own accord).
I contacted the dealer and Honda-Central told him to reprogram the keys to the car upon the first service.
I've had some other strange things associated with the key. Last time I washed the car, the doors alternately locked and unlocked every time I touched the car with the sponge.
I love the convenience of this electronic key stuff. But, I am not convinced it is secure or working properly. This is one of those ones Honda won't step up to. There is real dis-ensentive to admitting you can't engineer a keyless entry in this day and age.
Old Sep 24, 2015 | 01:22 PM
supera's Avatar
Make sure it knows which driver is in the vehicle.Programming the radio presets for driver 1 will have no effect for driver 2.While it moves the seat and mirrors for the other driver it also changes the radio presets.
Old Sep 24, 2015 | 05:15 PM
Puma Jim's Avatar
Maybe that is the problem! Always happens after she drives!
Old Oct 15, 2015 | 06:39 AM
Puma Jim's Avatar
Well when I take it in for first service I am going to tell them about this. I still routinely have the problem in that it will show different radio stations. Usually resets after I turn it off and then back on. Only complaint I have on my RDX
Old Oct 22, 2015 | 08:37 AM
visiter555's Avatar
I have found in the '15 & '16 it will occasionally "select" the wrong driver for no reason. If you walk up with the driver 1 fob it will set the RDX to driver 2 and the mirrors, seat AND THE RADIO will be wrong. Manually selecting Driver 1 doesn't change the radio, but does fix the mirrors and seat.
Stupid Acura can't figure out why it does that. First they say you must have had driver 2 close to the RDX. Well if they consider over 700 miles away as close, they could be correct.
Old Oct 22, 2015 | 08:38 AM
visiter555's Avatar
The only way to fix it that I have found is to exit the RDX with the fob, lock the doors pause and then unlock the doors with the driver 1 fob. Works 90% of the time...lol
Old Oct 25, 2015 | 08:26 PM
tcs55's Avatar
5th Gear
I have had this happen several times and I'm the only driver of the vehicle. I took it to the dealer two weeks ago with photos to show. Service manager said they had never seen this happen before. They called mother acura and got the same response. Told me to wait and see if it happens again, then bring the car again. Total waste of my time. Gonna try another dealer if it happens again.
Old Nov 23, 2015 | 01:25 PM
dirleton's Avatar
Then you will waste your time twice.
Old Nov 23, 2015 | 02:39 PM
RDX-Rick's Avatar
I agree that this is not normal, and it was slightly annoying to have this happen in a brand new vehicle. But since it only occurs in about 1 out of 10-15 starts, and I can resolve the problem in literally 1 second by turning the radio power on and off, it's not worth the hours of time it would take to bring it to dealer.
In fact, even if you did convince the dealer to replace your unit, it sounds like they all have the problem, so complaining is a total waste of time. At least until they learn what is causing the problem and can find a resolution.
Old Nov 23, 2015 | 02:58 PM
ceb's Avatar
ceb
Incorrect. Without complaints, Acura will not know the magnitude of the problem.
Since many dealers are clueless, call Acura and let them know about your problem and your dealer experience.
Old Nov 23, 2015 | 09:16 PM
tcs55's Avatar
5th Gear
Fortunately, not in my case.
Old Mar 9, 2016 | 09:23 PM
CrimsonElan's Avatar
Seems there is a new TSB about this, and seems the tuner unit is faulty, not just software issue.
See the sticky TSB thread.
Old Mar 22, 2016 | 12:10 AM
Stanuwmad's Avatar
I just test drove '16 RDX and the same thing happened - FM stations displayed Jebrish and then after I went back to the menu, they were fine. So is there going to be a fix for it? I can't believe they let the car to be sold like that *sigh*.
Old Mar 22, 2016 | 05:21 PM
jbernardk's Avatar
I just got a 2016 and had the radio problem on the third day. Also, could not pair with my phone after it was working OK for a few days.
Old Mar 23, 2016 | 06:29 PM
tcs55's Avatar
5th Gear
See the TSB. I just got mine replaced today. So far so good.
Old Mar 29, 2016 | 05:30 PM
colt427's Avatar
Only a few days but no radio issues so far.
I'm very pleased with the sound quality.
Old Jul 5, 2016 | 11:16 PM
Nitefall's Avatar
No problems like you guys describe with my 17 Advanced. but I do think the rear speakers are really low. i have to go 3 bars to the rear to even it out the sound level to the front.
Old Oct 20, 2016 | 11:58 AM
Shivers37's Avatar
3rd Gear
I have a 2016 advance RDX they denied the radio problems on my vehicle. I went months without a working radio. the radio was finally replaced. The front parking sensor go off for no reason. All the sensors were replaced and the problem is not fixed. The rear hatch opens by itself in the middle of the night. Multiple electrical problems when it rains. The brakes make noise constantly. Acura refuses to help.
Old Oct 20, 2016 | 11:59 AM
Shivers37's Avatar
3rd Gear
did they ever figure out why the hatch opens by itself? mine does the same thing and they cant fix it
Fabian43
Jul 13, 2016 09:07 PM
jjgoblue33
Nov 26, 2015 12:39 PM
govtcheez
Oct 1, 2015 12:21 AM
Iain MacLeod
Sep 16, 2015 02:38 PM
dlevesque
Sep 16, 2015 10:18 AM
