'16 RDX AcuraLink APP (iphone)
Old Sep 11, 2015 | 07:51 AM
Barb Jackson's Avatar
Picked up my new '16 RDX (AWD nav & tech pkg) this week. To date, the AcuraLink APP on from my iphone does not connect to the car. I have been on the phone with tech support for hours ... they have not resolved this issue.
Is anyone else having trouble with the AcuraLink APP via iphone (ios 8)?
Thanks.
Old Sep 11, 2015 | 08:12 AM
RSX_Takashi's Avatar
I had problems with the app. The app was able to connect to the car 3 - 4 hours later.
have you tried installing the app on another device? It should be able to connect to the car provided the device has a staple internet connection. The car is connected to the internet via cellular network (I think and I could be wrong). Perhaps you can try moving your car to a different location and try again.
P.S. I use an android device and it "should" work similar ways as your iphone. The app might be a bit inferior but it works.
Old Sep 11, 2015 | 08:29 AM
RDX-Rick's Avatar
Originally Posted by Barb Jackson
To date, the AcuraLink APP on from my iphone does not connect to the car.......
Thanks.
Have you been successful in connecting to your RDX via the web browser?. If the browser connection fails to work, then the Iphone app isn't likely the cause of your problem.
I assume that since you have been working with the support people, that you have already created a "My Acura" account , because you will not be able to connect without first creating an account.
Here is the URL to login to "My Acura" (USA site) using a web browser. Click Here.
Old Sep 11, 2015 | 09:04 AM
It appears a bigger issue is in play. Yes, all the respective accounts have been established. I allowed tech support to sign-in with my ID to send a command. Technical support was NOT able to send the command "flash lights" to my '16 RDX.
Old Sep 11, 2015 | 09:22 AM
RDX-Rick's Avatar
You mention that Tech support was unable to send a command. Is it just remote control that you are having problems with or are also having problems checking the status of the vehicle ( tire pressure, oil life, fuel level, etc).
Since owning my RDX for 3 months, I have had three occasions where I could not communicate with it. The first time I called the concierge service (by pressing the blue button). All they could do was give me the phone number for tech support, but after completing the phone call, I had regained access to the vehicle via my Android App.
The second time it occurred, I brought it back to the dealer. They plugged in their diagnostic equipment and everything tested normal. After unplugging their equipment the system began to work normally again.
A week later it failed again. This time I pushed the blue button, waited to hear the list of menu options, and then hung up. That was all it took to wake the system up.
As an IT tech myself, I know it is very difficult to diagnose intermittent problems like I have with my RDX. However your continuous problem should have been easily identified by the support techs.
PS If you haven't already done so, it costs nothing to press that blue button, and hang up after listening to the menu.
Old Sep 11, 2015 | 10:16 AM
Using the AcuraLink phone APP, it does not connect to the car to allow for checking status of the vehicle ( tire pressure, oil life, fuel level, etc).
When I hit the BLUE LINK button from within the car, it takes over 2 minutes to connect, and then screeches like the old fax lines. When I spoke to the concierge service yesterday and they directed me to technical support.
At the dealership, the day I picked up my car, the phone app never connected to the car. You can see all the car data from the Acura Owner web-site and Acura Link web-site. I have uninstalled the application from my iphone, rebooted the iphone, and did a reinstall, nothing is working.
I appreciate you insights and will share your information with my local dealer. Hopefully this issue can be resolved.
Old Sep 11, 2015 | 11:48 AM
RDX-Rick's Avatar
Well that is certainly not normal. This indicates that the vehicles built-in cell phone is not working properly, and it is this cell phone that provides the remote connection via the My Acura app. Is it possible that you are parked in a bad area for cell phone coverage? (underground parking for example). Have you tried connecting while your vehicle is parked in other locations?
In my earlier post I asked if you could connect from the web site, and you gave me the impression that if failed to connect from there as well. Are you now saying you "CAN" connect from the web-site, or is this just a typo?.
Old Sep 11, 2015 | 12:35 PM
1. I have tried to access the Blue Link button from several locations around the city and non of the locations were in a parking garage. I have strong cell service at all the locations.
2. When I access the link you provided earlier, Acura Owners Account. I see everything about my RDX. Is there a location on this web-site, that "talks" to the RDX, ie: flash lights? Please expand, Connect from the web-site.
If this web-site does "talk" to the RDX, please navigate me to that specific location.
Old Sep 11, 2015 | 01:38 PM
RDX-Rick's Avatar
I am registered with the Canadian My Acura site, and my username and password do not work on the USA site, so I cannot give you specific instructions. I will try and give you some guidelines via the following images. Note that I have blocked out personal identifying information.
After logging in with your username and password, you should see something like this. Choose the AcuraLink tab, at the top right corner.
You should then have a choice of which of your Acura vehicles you wish to examine. If you only have one, then you will be brought directly to it. Click on the "Get Vehicle Status" button to retrieve the status. This takes an exeptionally long amount of time ( about 50 seconds) before you will see the results. If you have a problem connecting to the vehicle, you will be told so after about 50 seconds.
If it works you will then see the 3rd image on your screen.
You can send remote commands by clicking on the "REMOTE" tab in the 3rd image.
Old Sep 11, 2015 | 01:49 PM
Very helpful! I do not have this. I will be visiting my dealership and let them figure this out.
Thanks for all your time. I will post an update (as soon as I have one).
Old Sep 15, 2015 | 02:18 PM
Update. After waiting almost 72 hours everything finally sync'd with the AcuraLink servers. I now have full access to the remote commands from my iphone and the AcuraLink web page.
Old Sep 15, 2015 | 02:27 PM
That's awesome. Did you ask Acura to extend the free 1 year trial by 1 month? It doesn't hurt to ask.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
San Yasin
Sep 29, 2015 10:52 AM
dirleton
Sep 29, 2015 08:26 AM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
