Squealing brakes
Old 10-13-2015, 01:17 AM
  #41
8th Gear
A Chia Hung Chang's Avatar
My 2016 RDX has the same issue - breaking squeeking.
When it at about 40 mph and not to hit the brake to hard. The sound will come out, ready to dealer to fight the issue.
Old 10-13-2015, 12:34 PM
  #42
giovane's Avatar
Almost 1000 miles after the dealership resurfaced the front rotors and I haven't heard any squeal since.
Old 10-22-2015, 12:20 AM
  #43
YeuEmMaiMai's Avatar
you have to eliminate all of the metal to metal contact outside of the pad on rotor contact area. I have found that using anti-seize on the brake ears (tabs) the area where the piston(s) contact the caliper, and where the fingers of caliper contact the outer pad.
I have done brakes on many different types of cars that I have owned or that friends have owned and never had brakes squeal afterwards.
Old 10-22-2015, 03:53 PM
  #44
8th Gear
After resurfaced the front rotor and new brake pad. No more squeal noise so far. All of above is covered by Warranty.
Suggestion…Take the video before you go, some mechanic may not be patient to find out the issue.
Old 11-21-2015, 08:43 AM
  #45
cbptls's Avatar
Definitely recommend you need to try to take video of it, because when you try to replicate the issue for them, it everything seems to work fine.
We already had our rotors resurfaced and new brake pads installed, however the same issue is occurring again. Now the dealership is insisting this is normal and trying to make all types of silly excuses.
Old 11-21-2015, 09:24 AM
  #46
snorf's Avatar
Mine started squealing (a deep squeal as opposed to high pitched) at about 2,000 miles. I live an hour from the dealership and the day before I took it in, the brakes stopped. Now it's intermittent. I know the accord had a class action lawsuit on their brakes (premature wear), but I don't know if the RDX has the same brakes or what the exact issue was with the accords.
Old 11-23-2015, 09:07 PM
  #47
5th Gear
tcs55's Avatar
Got my fronts replaced two weeks ago, no more squealing.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
rockyboy
10-02-2015 10:45 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Squealing brakes
