Power lift gate
I think that your.... S.O.L. on that possibility. Should'a, Would'a... Couuld'a, Bought the Tech package and got most of your $$ back at resale time. And enjoyed the use of all the tech items. Unless your a Canuck... The Tech was the prudent way to go. Good luck.
As always.... IMHO.
As always.... IMHO.
You don't tell us where you are but you want the name of a shop to retrofit?
It is immaterial anyway because the costs of parts and labor would far exceed the cost of trading your car in and buying a tech.
As always.... IMHO.
As always.... IMHO.
The things I don't like about the power lift-gate on our MDX are:
- really slow compared to open/close it manually
- you have to unlock the car and then press/hold the hatch button, why can't I just unlock the hatch and/or doors at the same time (M.I.D. setting option)
- no height adjustment if the open hatch hits garage door opening (hits the door and goes back down).
It is a nice to have item; but, I would not trade my current RDX just for that feature alone.
normally it isn't too hard to actually add the power lift gate but in this case you will need
1. Lock closer assembly #11, $170
2. button on liftgate #12, $32
3. Screw #58, $1
4. Buzzer assembly #26, $36
5. Sensor assembly #27, $120
There are most likely other things needed but I am not sure
That's at least $400 in parts and that does not include the $100 key fob
http://www.acuraoemparts.com/delray/...All&vinsrch=no
3. Screw #58, $1
3. Screw #58, $1
3. Screw #58, $1
Wiring harness ? Cost for dealer install or if you DIY, the cost to flash the computer and reprogram? FORGETABOUTIT.....
wiring harness is most likely already there as are the required software module. Everything communicates on a CANBUS so once it was installed it would most likely work
I see you have two (2) "most likely" in your post....
Is that like, Maybe, could be, should, or coulda been, shouda been and woulda been ?.... "Most likely", Means, I wish it woulda been (lol).
Never assume... When Acura (cheap skates) built the car, they didn't even want to spend the extra money to make the passenger seat go up or down.
Maybe they put all the other parts you listed along with the hypothetical wire harness? Just add the button and the hatch goes up?
The Acura company glass is half full? For us owner's that want to add a auto hatch, rear ac vents, up/down passenger seat and a nav that I can use when I drive.... I don't think so.
Maybe, take a look inside the rear fenders.... Might be lane departure sensors in there (LOL).... dreamer.
^ lol
ok let me spell it out for you
it is cheaper for them to make 1 harness vs 2 for said vehicle. This allows them to customize each one as it comes down the line. This isn't rocket science...
It is also cheaper for them to load 1 software on said computer and have it auto configure based upon what's plugged in, again this is cost effective... and not rocket science...
lol I bet you think MS makes multiple versions of Windows distributions.... lol nope, your key and a configuration file are the only differences between versions... the core package is the same and it has been that way since WINNT 4
and obviously you are pissed off about something regarding acura so maybe next time do some research before you buy your car?
^ lol
Once ALL of the required bits are added up (I suspect some of the trim pieces are different and where is the motor to make it all happen - that isn't the "lock closer assembly") you'll find that parts will easily exceed $1000. Installation will add another chunk of change since much of the interior will require disassembly.
Are you sure that the wiring harnesses have the same part number? In my experience, manufacturers DO use different parts rather than combining then. The example of Windows was a bad one because with software it is easy to turn features on and off - not that easy with hardware where every extra strand of copper costs money. In general, manufacturers don't like to leave open connections dangling about.
A prime example is VW where models with and without foglights have different harnesses with the differences being a couple of fewer wires in the non-foglight models. Dealers will generally only stock the "with foglight" version as it works for both but two separate harnesses are used at the factory.
These types of retrofits are usually much more expensive than initially expected by a quick perusal of a parts diagram and often lead to electrical issues down the road.
My prediction is that a retrofit at an Acura dealer would exceed $3k.
Oh, if you compare parts lists to the "non-tech" version you'll note that the tailgate itself has a different part number - so add $556 to your estimate. I didn't bother looking at the other pieces but I'm sure that you'll find many subtle differences that add up.
Power lift gate
I'm not and I quote pissed off at the Acura end of quote.As YeuEmMaiMai stated.
I only wanted a power lift gate but was not avaible as a option on the RDX had to buy the tech package to get a power lift gate didn't feel it was worth the extra money.
Jul 16, 2017 07:33 AM
