Driver Side Door Panel Removal Help?
Old 01-17-2018, 08:05 PM
8th Gear
misturnice's Avatar
I have a 2017 Acura RDX. Has anyone removed their driver side door panel - i.e. upgrading of speakers etc.
I am looking to remove the door panel. I can clearly see the 2 screws right behind the door handle lever cover.
I believe there should be at least one more screw? Has anyone done this and knows where there may be additional screws?
Thanks!
Old 01-22-2018, 08:49 AM
speed817's Avatar
There's another screw in the door handle that is hidden beneath a cover. The cover was a pain to remove. I used a small, thin screwdriver to pull one side up and pop the cover off. Once you get those screws out, just use a panel remover tool to pull the whole panel out.
Old 01-22-2018, 04:14 PM
8th Gear
misturnice's Avatar
Thanks for the reply, I checked the parts list/diagram for the door panel over the weekend and made the assumption that there was a panel under there
However for future reference if anyone searches this post.
The third screw is located in the "coin holder" on the arm rest, right behind the Driver side window/mirror switches. The cover plate is a rubber/grippy surface 100% bendable, theres no slots for you to shove a screw driver in so you might miss it at first glance. You can pry it up with a small flat head to expose the screw.
Has anyone found any location to purchase the Service manuals for this car?
jomasonvt
01-05-2015 06:33 AM
Joseprofet
01-20-2012 07:09 AM
TampaRLX-SH
05-25-2010 01:51 PM
silvernight
03-10-2010 02:08 AM
compguy7
1G TSX Problems & Fixes
04-22-2005 12:28 PM
Quick Reply: Driver Side Door Panel Removal Help?
