Dash Cam Power Adapter
Old May 30, 2022 | 04:44 PM
Al Dente's Avatar
Anyone have experience (good or bad) with the Dongar Technologies Dash Cam Power Adapter that plugs into the 7 pin connector on the rear view mirror?
Old Jun 1, 2022 | 10:16 PM
msklut's Avatar
8th Gear
This past weekend I installed a Garmin Dash Cam Mini 2 with the 7-pin power adapter from Dongar. It was a seamless installation and everything is working great. Keep in mind, if you need “parking mode” on your dash cam then you would need to have a hardwire to the fuse panel. Otherwise, the Donger adapter is very slick and makes for a simple setup.
Old Jun 2, 2022 | 11:30 AM
msklut's Avatar
8th Gear
Here's a pic of the dash cam with Dongar 7-pin adapter. I used a small piece of velcro strap to keep the pin adapter and USB cable together. Also, recommend using a short (6 inch) right angle micro-USB for the camera.
landser1111
Jul 21, 2017 11:49 AM
SuperCK
Sep 15, 2015 10:03 PM
gen2gsr
Jan 27, 2008 09:04 PM
lf05tl
May 28, 2006 02:28 PM
