Cleaning RDX interior surfaces
Old May 31, 2021 | 05:03 PM
iHondaGuy's Avatar
Hey, what do you use to clean the interior surfaces especially a dusted covered dashboard?
Old May 31, 2021 | 05:27 PM
fjpthree's Avatar
Water....If you use a chemical on your dash it will cloud the inside of your windshield once the sun hits it.
Old Jun 6, 2021 | 08:09 PM
dtownfb's Avatar
I use Armor All Interior wipes on the hard surfaces. I picked it up at Walmart. I'm sure there may be a better product if I took the time to research it.
Old Jun 7, 2021 | 04:20 PM
jimbo1763's Avatar
I think that water is a pretty good solution. What you don't want is something that will electrostatically charge the surface and thereby attract the dust. That just makes it worse in the long run.
Old Jun 7, 2021 | 09:22 PM
Clickit02's Avatar
Add to a gallon of water a spoon of liquid soap. Liberally brush surface with solution and wipe off with microfiber clothe. This is all you need.
Old Jun 7, 2021 | 10:10 PM
DUCRDX's Avatar
Strike Hold
Tons of dust where I live. I just keep a microfiber cloth in the car and wipe the dash and everything else with it
Old Jun 9, 2021 | 03:09 PM
hongthan's Avatar
Me too. I usually clean the dash with wet cloth first, then apply the Armor All.
Old Jun 17, 2021 | 02:18 AM
Falconee's Avatar
Use Aerospace 303 on the dash and rubber seals around the doors and sunroof. I have been using it for over decade and its the only thing that keeps rubber soft
Old Jun 19, 2021 | 05:01 PM
Mandu's Avatar
It depends how dirty your interior has become. If dusty but clean overall, use a simple all-in-one interior cleaner that has UV protection. European car owners tend to use higher cost German products like Sonus or Nextzett, but in my experience they all work similar. I gravitate towards 303 Protectant because it works well on both interior and exterior trim. Regardless, I stick to decent brands that I can find locally. Wal-Mart is usually stocked and cheapest, else the usual Autozone/O'Reillys. Stay away from Armor All products.
Meguiar's Quik Interior Cleaner
Chemical Guys Total Interior Cleaner
303 Automotive Protectant
Adam's Interior Detailer
Griot's Interior Detailer
If you need a deeper clean, I keep it simple and use hot water and natural soap like Seventh Generation dish soap with a clean scrubber. For an actual car cleaner product, I've had good luck with Chemical Guys Nonsense All Purpose Cleaner. You can dilute it to the strength you need, and its fairly cheap. I use it on my engine bay as well.
Hope this helps.
rockyboy
Oct 13, 2016 05:17 PM
saxman48
Jun 9, 2013 02:19 PM
CJMack
1G RDX (2007-2012)
Jun 7, 2008 07:34 AM
smak01
1G RDX (2007-2012)
34
May 5, 2006 08:18 PM
rmralston
1G RDX (2007-2012)
15
Apr 18, 2006 10:46 PM
