Check Keyless Starting System
Old Sep 10, 2019 | 04:10 PM
Vegeta-x's Avatar
7th Gear
Exclamation Check Keyless Starting System
Hi, I have a Acura RDX 2013 AWD I have "Check Keyless Starting System" comes I have taken to dealer / 3rd party shops and run diagnostics on car and find no issues they
do some sort of a reset and the message goes away and then a few weeks or months later the message comes back has anyone else seen this or experienced this?
Old Sep 10, 2019 | 04:11 PM
Vegeta-x's Avatar
7th Gear
forgot to mention the car has no issue when this light comes on its just annoying to see everyday
Old Sep 10, 2019 | 08:46 PM
egads's Avatar
Have you changed the fob battery? Where do you keep the fob? You might try and see if there is some pattern with respect to other things in your pocket or bag.
When you are home, if you park in the garage, make sure your key is not too close to the car.
Old Sep 11, 2019 | 09:13 AM
Vegeta-x's Avatar
7th Gear
Hi, I replaced batteries on both fobs that I have last year when I get into car the fob can be in my pocket or sometimes I just take out of my pocket and place in cup holder. I don't own a garage so I park in the streets sometimes a 1/2 block to a block away
Old Sep 17, 2019 | 07:45 PM
Vegeta-x's Avatar
7th Gear
someone told me to take key out from fob and leave key on door while car is turned on gave it a try and it did not help
jubikej
Mar 26, 2024 08:34 PM
RDXRSXTL
3G RDX (2019+)
May 6, 2019 06:06 PM
bradykp
1G TSX Problems & Fixes
May 19, 2014 02:12 PM
natavio
1/2G MDX (2001-2013)
Jan 8, 2014 05:58 PM
iliketenafly
Jun 6, 2005 03:26 PM
