Check Emissions Light Keeps Coming on and off - ? sensor broken
Old Mar 27, 2021 | 12:24 PM
cdoobiest's Avatar
Hi everyone, I have 2016 RDX with approximately 72,000 miles on it. I noticed the check emissions light comes on when tank initially 1/8 left in it, then 1/4 tank and now 1/2 tank full. Initially, I thought it was because gas cap not closed tight but everytime I fill up now (3 times full gas since light came on), the light would go off after but then reappear around the 1/2-3/4 tank mark. Wondering if there is faulty sensor in gas cap that could be causing this? I just had my MA emissions sticker done and it passed so I do not think it's anything too major?
Any input?
Old Mar 27, 2021 | 12:45 PM
I would go through the emission system...
I would check the EGR, PCV and the evap purge valve and the gas cap.
check for carbon debris in EGR.
Check for the valve in the PCV.
check to see if the gas cap seal is still good.
and lastly check the valve in the purge valve
Old Mar 27, 2021 | 08:17 PM
Clickit02's Avatar
Replace a gas cap. It is cheap and may be a culprit. It also may take several trips to reset.
Old Mar 28, 2021 | 07:09 PM
egads's Avatar
The thing to do is have the codes read. Then you are not guessing.
WojciechR
Jul 19, 2021 01:44 AM
rob-2
Nov 28, 2020 07:01 PM
t_in_maine
1G TSX Problems & Fixes
34
Dec 4, 2007 10:18 AM
dannycls
2G CL Problems & Fixes
Mar 24, 2007 10:15 AM
natrlmystic
1G TL (1996-1998)
Jul 30, 2004 07:59 AM
