Change the default screen to audio instead of maps
I have a 2013 RDX w/tech package, is there a way to make the screen default to the audio screen instead of the map screen, I rarely use the navigation and would rather default to the radio after the annoying warning message.
I don't think You can default to audio.If You don't select ok and wait for the display to time out .You can select either a blank screen or a a star pattern.I never use the nav screen.I let it time out and go blank.You can at anytime select audio or nav from the blank screen.
On my 18 Rdx, i have music loaded on a usb flash drive. I have it in the usb port and i press the Audio button for the playlist. Every time I start car, i get the normal warning message and then goes straight to my USB playlist.
jnoone
Sep 21, 2010 11:04 AM
beanman67
Jun 2, 2010 07:24 PM
msterling21
Jan 27, 2006 01:30 PM
