Change the default screen to audio instead of maps
I have a 2013 RDX w/tech package, is there a way to make the screen default to the audio screen instead of the map screen, I rarely use the navigation and would rather default to the radio after the annoying warning message.
I don't think You can default to audio.If You don't select ok and wait for the display to time out .You can select either a blank screen or a a star pattern.I never use the nav screen.I let it time out and go blank.You can at anytime select audio or nav from the blank screen.
I'd like to elimite the warning screen all together and just go to the audio
Can't be done.
On my 18 Rdx, i have music loaded on a usb flash drive. I have it in the usb port and i press the Audio button for the playlist. Every time I start car, i get the normal warning message and then goes straight to my USB playlist.
After the warning screen it defaults to the playlist without pressing audio?
Yes, I tried this with FM radio also.
