Can't remove a spark plug
Old Apr 17, 2024 | 08:47 AM
  #41
emry's Avatar
Originally Posted by TheSauceBoss
Man this thread went downhill lol. I just want to know if OP ever got that plug out! (For what it's worth, changing the plugs at 75k is ridiculously early, unless you have a 1st generation VCM J series that fouled the F out of the plugs or something).
You are right. I also feel the thread is kiddda hijacked. Not a good thing. I wouldn't like if someone did the same thing in my thread.
Old Apr 17, 2024 | 09:06 AM
  #42
rdx4me?'s Avatar
Yeah I'd like to know as well...Just a thought pulling the valve cover might help expose the cause of the issue?
Old Apr 17, 2024 | 10:12 AM
  #43
Alex Medeiros's Avatar
alexmed2002
Originally Posted by emry
How many recalls Toyota has had? Any idea? The Takata airbag scandal of Acura was not a security lawsuit?
The takata airbag issue affected a bunch of manufacturers (Acura, BMW, Chrysler, Dodge, Ford, Honda, Mazda, etc.). It was an issue on my family when they had Subarus too. That's all I'm gonna say and not hijack the thread anymore lmao.
Old Apr 17, 2024 | 07:29 PM
  #44
Clickit02's Avatar
Remember this is just a recommendation. Acura also recommends the timing belt to be changed at 105K miles. Your belt may not snap even to 200K miles or it may does so at 90K miles. The question is do you want to wait till the last second and when it happens to go for the repair. The discussion here was whether is a good practice to replace plugs early for better performance not that new plugs can't go up to 100K miles. Read my earlier posts. I said your plugs may also work up to 300K miles but do they work properly. That was my question and I haven't seen independent studies to prove that. If you come across such studies post here and I read it.
If we just go by "feeling good" you could also go with your plugs past way 105K recommended by Acura since not replacing them and spending on them naturally feels good. Why would you change them at 105K miles if they still work in your books?
You contradict yourself: If Acura, or Lexus, or whatever manufacturer specified service intervals to replace a particular component, while they work as designed (e.g. timing belt or spark plugs, or whatever), they for sure know that these components will work correctly and last beyond recommended interval. Therefore, 120K miles is not just save for spark plugs, but super safe.
It appears that we may highjacked the thread, so let’s stop our back-forth. You have you opinion and I, with many others have mine. Let’s leave it at this.
Old Aug 17, 2025 | 06:25 PM
  #45
wallmike's Avatar
I never got it out. I tried this weekend after driving the car for a while. it was nice and hot.
I had trouble getting the socket to sit on the plug and grab it. I have to push down hard.
I did get an endoscope to look in at the plug after removing the ignition coil. I couldn't see what if anything is preventing the socket from grabbing the plug.
It seemed rusted at the bottom. Sprayed penetrating oil. Saw some bubbles. Tried again after 30 minutes. No dice.
Was able to remove plugs in cylinders 2-6 with no trouble and replace them.
This stuck plug has about 100k miles on it. May be a bit more.
I am going to get a mechanic work on it tomorrow. Previously another mechanic refused to work on spark plugs because I told him I couldn't get it out.
Praying it won't strip the threads or break off.
Old Aug 18, 2025 | 07:41 PM
  #46
wallmike's Avatar
Found the problem. It seems a black rubber boot from inside the socket got onto the plug and is preventing socket from sliding all the way down and grabbing onto the plug.
Tried to pull it off the plug with a thin screwdriver. Won't come out.
I have to get one of those dentist cleaning tools with really sharp edges and retry.
Old Aug 19, 2025 | 02:50 PM
  #47
jjrphs's Avatar
I had that thought...but was also thinking that the same spark plug socket should've fit right back over that orphaned rubber piece. Besides a dental pic set, I would also suggest investing in a hemostat / forceps set...they come in handy in so many ways.
Old Aug 19, 2025 | 05:56 PM
  #48
wallmike's Avatar
I tried that. It doesn't fit. The socket doesn't grab and turns freely. I am getting loooong thin tweezers tomorrow. Will try again.
I finally got a photo.
Old Aug 20, 2025 | 03:09 PM
  #49
dvd2012tl's Avatar
The rubber section of the spark plug removal socket is supposed to grab the porcelain section of the plug to pull it out after you unscrew it. If it's still down there, how did you get the coil back on and drive it for over a year?
Old Aug 21, 2025 | 03:32 PM
  #50
Poolman's Avatar
That rubber part has been on there so long that I betting it's about melted onto the head and plug itself. Your going to need to figure away to cut it off and out of there and will take some time.
What ever you do, make sure you DO NOT try to remove that plug with a hot engine. Remove the plug when the engine is stone cold. Removing a spark plug on a hot engine
with aluminum head is a great way to strip the threads and then have to install a time- sert . Good Luck !
PS
You might try using some brake cleaner and see if that might make the rubber part melt some and make it more ply-able to remove a bit easier , but you do have to contend
with what the heat has done to that bugger.
Old Aug 21, 2025 | 05:18 PM
  #51
wallmike's Avatar
I tried long tweezers. No luck. Pick tool. Nope. Bought really thin hacksaw blade. Will try to cut it and then remove with tweezers.
It is not easy working with the awkward location of the cylinder.
Old Aug 22, 2025 | 05:37 AM
  #52
Poolman's Avatar
Long Jigsaw blades with needle nose vice grips might be your friend
Karanx7
May 22, 2011 09:29 PM
thku4grace
1G TL Problems & Fixes
Jan 25, 2009 07:04 PM
Easy one 7
1G TSX Problems & Fixes
Nov 7, 2008 07:26 AM
Cseika
Mar 30, 2004 10:51 PM
KC CL 1785
May 28, 2003 04:16 PM
