Bluetooth Problem. :(
Old Dec 19, 2020 | 04:06 PM
g.guess88's Avatar
8th Gear
Hello Fellas,
I have a 2Gen 2014 RDX Tech.(75k+-)
Just last week, my Bluetooth music stopped working, FM/AM radios stopped working as well, however, HFL still works???
The speaker rings when I have an incoming call, I can talk on it no problem. Speaker has no sound only when playing Bluetooth music or radios, any thoughts on what is wrong?
HFL: working
Bluetooth Music: not working (no sound)
FM/AM radio: not working (no sound)
Please advise, I really don't want to take my car to the money robbing dealership.
Old Dec 19, 2020 | 08:12 PM
Alex Medeiros's Avatar
alexmed2002
Have you tried un-pairing your phone from the car and setting it up again? Also try unplugging anything in your car and try the radio. As far as your bluetooth, I'd try to delete your phone as I mentioned before and try a different device to see if the issue persists.
Old Dec 19, 2020 | 09:22 PM
g.guess88's Avatar
8th Gear
What I have done already to try to solve the problem, as follow
1. reset radio
2. un-pair phone (delete) + pair
3. pair to a different phone
4. unplugged all accessories in car
5. unplug car battery
After doing all of the above bluetooth music and radio still does not work
Old Dec 19, 2020 | 11:54 PM
alexmed2002
Have you tried using the AUX port? The impression that I am getting is you're not getting sound, but still getting power to the head unit and still able to connect a bluetooth device. Make sure to check that none of your fuses are burnt out either.
Old Dec 20, 2020 | 10:22 AM
samiam_68's Avatar
Also, try playing a CD, see if that works.
Old Dec 22, 2020 | 09:19 AM
g.guess88's Avatar
8th Gear
Hey guys.
Few days back, I tried the AUX port (not working) CD player (not working).
This morning. I needed to run an errand, started the car like I normally would, drove out the garage, about 5 min into the drive, my bluetooth music started blasting......
does this sound like a fuse problem?
Old Dec 22, 2020 | 01:34 PM
alexmed2002
Originally Posted by g.guess88
Hey guys.
If it were a fuse issue, then the fuse would have to either be 100% blown or still working like normal. My gut tells me that it seems like you might have loose wiring or maybe something got slightly unplugged.
Old Dec 22, 2020 | 10:08 PM
g.guess88's Avatar
8th Gear
That makes sense, the fuse is either working or not working, won't be intermitten
Alexmed2002 any idea where I can start checking?
Old Dec 22, 2020 | 10:31 PM
alexmed2002
To be honest I'd check all the plugs and wiring behind the stereo. You would have to take apart the center console, but you might find your issue. If nothing seems wrong, maybe try getting a used OEM stereo and see if that changes anything. Electric gremlins are the worst.
Old Dec 23, 2020 | 09:05 AM
dtownfb's Avatar
Is the bluetooth and radio working today?
Check the connections at the battery as well.
BTW, what phone do you have? Was there a recent update to the phone?
Old Dec 24, 2020 | 02:19 PM
g.guess88's Avatar
8th Gear
Hello dtownfb,
Yes, so far it has been normal (fingers crossed).
I did check the battery connection when I unplugged for testing, cleaned the terminals, and applied new grease as well.
I have iPhone 12 Pro, the phone is on auto-update, just checked it now and it's on the latest ios version.
I'm hoping the rdx is just throwing a tantrum for not driving it enough, the car is on battery tender almost 4 days out of the week since I have multiple vehicles that need their share of the road.
Old Dec 24, 2020 | 02:45 PM
alexmed2002
I wonder if this is causing the issue.
Old Dec 25, 2020 | 12:26 PM
g.guess88's Avatar
8th Gear
Alex,
More towards being parked and not moving for a long time? Or the battery tender?
Old Dec 25, 2020 | 02:02 PM
alexmed2002
Alex,
The battery tender. Cars can be picky sometimes.
Old Dec 25, 2020 | 10:16 PM
g.guess88's Avatar
8th Gear
Thanks, Alex, I will unplug it and see if the problem ever comes back. So far so good
Old Dec 26, 2020 | 01:57 AM
alexmed2002
Hoping you have good luck from now on .
#1 STUNNA
Technology
603
Mar 28, 2026 08:58 PM
liono
Sep 29, 2010 09:52 PM
djrayray
Feb 2, 2009 08:26 PM
lnghorn00
May 12, 2005 05:07 PM
