Bad wheel bearing
Old Sep 14, 2018 | 06:32 AM
chickdr's Avatar
Bad wheel bearing
Just an FYI for others. Our 2016 with 50k miles has had a mild vibration at highway speeds over the past month or so. I thought it was tire related as they were in need of replacement. I swapped out to Yoko Avid Ascends. This did nothing to help. Started noticing a grinding type noise towards the front of the car especially at low speeds. Took it in to have it checked out. Found a bad wheel bearing. Was told this is fairly common even at 50k. Car is good now and it was covered under warranty.
Old Sep 18, 2018 | 07:17 AM
Tech's Avatar
Maybe on an RDX although I can't see why.
The original front wheel bearings on my old CR-V just clicked over the 300K km mark (186K mile).
Old Sep 18, 2018 | 08:38 AM
Brown13's Avatar
They found a left rear wheel bearing on Mine at 55,000 during transmission service.Apparently the only way to check on AWD,is to have it on the air and in gear.I had noticed no noise or vibration.
Old Sep 18, 2018 | 04:56 PM
Poolman's Avatar
Apparently the only way to check on AWD,is to have it on the air and in gear. Ummm, does this mean the have to get the car on a lift to find the problem?
Old Sep 18, 2018 | 08:19 PM
Brown13's Avatar
That is correct.On a lift and in gear, wheels turning.
Skinny75
Mar 29, 2016 05:19 PM
3.2_Vtec
May 2, 2012 03:09 PM
AcRyte
1G TL Problems & Fixes
17
Jul 30, 2007 09:31 AM
Virginia Donkey
1G RL (1996-2004)
Apr 29, 2007 09:14 PM
leventis72
1G TL (1996-1998)
Aug 3, 2006 08:24 PM
