Advice when picking up 2016 RDX AWD Advance
2016 RDX Advance Blk/Blk
Hi!
I purchased a new 2016 RDX AWD Advance on Monday and expect to pick it up in the next couple of days.
I have been scanning the threads on this forum for advice of what to check for when I pick up the car. I've seen a few things - reflections of the frame around the vents off of the side mirrors, rattles in the sound system - but wonder if anyone has compiled a list of what a new owner should check for. I have looked and looked but am not seeing it. Thanks in advance for pointing me in the right direction?
Jane
Jane
Just make sure no scratches around the car. Most of the other stuff is under warranty, you can always come back later if an issue is discovered (e.g. noisy brakes). Reflection in mirror is not as bad as people are making it out to be. I didn't even notice it m until someone mentionned it.
Hi!
Jane
Jane
CJaneDrive (11-04-2015)
Another topic you may want to bring up is what gas to use - 87 or 93. Premium unleaded is "recommended", but it seems people using 87 octane are getting the same performance and the same mpg.
mrgold35
Since you are picking up the vehicle on Monday, is this the first time behind the wheel of this particular vehicle? I would road test as long as you can (hwy, side streets, rough roads, braking, etc...). If you can road test alone, maybe do a 1st inspection in a parking lot away from the salesperson looking over your shoulder. Then do another inspection at Acura with the salesperson.
It will mostly going to be any physical imperfections with the exterior or interior. They are going to say you caused the problem once you drive it off the lot and bring it back the next day. Inspect in bright sunlight, no rain, and second set of eyes if possible. I would double-check the usual areas of concern like:
- door ding areas,
- door handle scuffs,
- front and rear bumpers,
- hood and roof for dings or depression areas
- around the rear hatch area,
- front seats (seat bottom & upper side bolsters),
- rubber seal around doors
- door sill scuffs,
- road rash on rims
I might even check out the dealership on Sunday if it is closed to check out similar models on the lot to get a feel for the condition of the paint, trim, tires, wipers, rims and glass.
You can also download the pdf version of the 2016 owner's manual to get a feel for all the new bells and whistles: http://owners.acura.com/vehicles/inf...16/RDX/manuals
It can be information overload trying to figure the Advance features out in the middle of the hwy.
- door ding areas,
- door sill scuffs,
- road rash on rims
Snorf, good to know that the reflection of the vent frames isn't bothersome to you. From what I've read on here, it sounds like there are a few factors at play - other than the obvious factors of how bright the sun is and its angle in the sky - like the height of the driver and maybe how sensitive the driver is to the reflection. I'm going to hope for the best and go back to the dealer later if the reflection bothers me. Fingers crossed!
I'm sorry about your brakes. Frustrating!
Picking up tomorrow!
- door ding areas,
- door sill scuffs,
- road rash on rims
You can also download the pdf version of the 2016 owner's manual to get a feel for all the new bells and whistles: Owner's Manuals | 2016 Acura RDX | Acura Owners Site
- door ding areas,
- door sill scuffs,
- road rash on rims
I'll definitely check out the manual. Thanks for the link. Going from a 2008 car to a 2015 car should be fun - lot's of new tech! - but already I can see that figuring it all out could be overwhelming. The manual should help, plus it looks like there are quite a few youtube videos that explain various features.
I'm going to have fun!
Thanks for your help!
If you're able, post pics of the vehicle. Have your USB stick ready with nice wallpaper and music loaded. The wallpaper resolution is incredible. The sound system is something to behold. You will be very happy you chose the Advance. This thing has really cool gadgets!
Turns out that I'm picking up my car tomorrow! Still, I can follow this advice, except for checking out other vehicles on Sunday, that is.
CJaneDrive (11-05-2015)
Congratulations on the new car. The reflection of air vents happens in every car with chrome lined air vents, not just the RDX. The reflection is actually from the window (not the side view mirrors), more so if you tint your front windows. So if it bothers you, just lower the front window and you will be fine (of course not on cruising speeds). My guess is that you will notice it for 1-2 weeks and then forget all about it. Post some pictures whenever you get a chance. Good luck.
The following 2 users liked this post by Comfy:
CJaneDrive (11-09-2015),
rockyboy (11-06-2015)
I have driven my new RDX for a few days and noticed the reflection on the side windows. This would be more noticeable in the bright summer day than in the fall/winter. It is not a big issue but just annoyance.
Would PVC tape or black marker pen cover the reflection? It just sounds really stupid to use marker pen on my new vehicle.
Check door, front fender, and hood alignment. I've seen some real dogs on the lot. Mine is terrible in this regard. Very disappointing from Honda. Have not had this issue with past Hondas, which had superb build quality. Saw a '16 RDX at the dealership with a door that sagged so much there was 3/8" space at the top and less than a 16th of an inch at the bottom of the seam. Terrible from the company we've all come to respect for their attention to detail and quality.
Another area to check is the chrome weatherstripping along the bottom of the windows. The weatherstripping at one end of the passenger side rear window panel was sticking up just a bit higher than the rest and was a bit loose upon handling. Turns out that its a clip that holds it that needs to be replaced. Will get it done upon my first official service. Funny also that the loaner vehicle also had this issue in the same place!
A bit surprising about the finish but then again maybe I'm looking at this car a lot more closely than others I'd owned in the past.
Overall despite these minor issues, I am really enjoying the car so far.
I may be fat but I'm slow
Get yourself some all season floormats while you're there (Acura brand) or order some from Weathertech. Don't want to be tracking winter slop all over your new car. Enjoy.
Bruin
I even purchased the advanced running boards from an online Acura dealer and one side came with a large dent in it. I guess their QC these days is lacking.
We didn''t have these issues with our 2012 RDX, which was also purchased of the lot.
Check the handsfreelink and make sure everything works, especially the mic. Mine went dead within a week. I got it replaced via warranty so it's all good, but there may have been a bad batch or two that got fed to the factory.
onFyre
In the event that you do notice a ding or scratch at pick-up, what can one expect the dealership to do in response?
Would it be reasonable to get a discount for the blemishes?
A lot of them have decent body shops in-house, so they should be able to fix it up for you. All but the most treacherous dealers will do that for you for no charge. Wouldn't expect a discount, especially if it's after the 'handshake'.
auzie88
11-20-2015 01:20 PM
iiamchili
11-03-2015 10:26 PM
