3 and 4 cyl mode
Old Aug 14, 2013 | 09:24 PM
pistol champ's Avatar
6th Gear
3 and 4 cyl mode
Has any one wired something up so that you can tell when the engine is in 3,4,6 cyl. modes?
Old Aug 14, 2013 | 10:21 PM
markAZ's Avatar
I wonder if something like a Scangauge would show it?
Old Aug 15, 2013 | 08:07 PM
BLEXV6's Avatar
Nope, but I can feel them deactivating.
Old Aug 16, 2013 | 12:01 PM
ipribadi's Avatar
Still don't understand why they don't show this on the center info display when its showing mpg. Just a small "VCM3" and "VCM4" pop up would have been perfect.
Also I do wonder, is VCM engaged when idle?
Old Aug 16, 2013 | 12:51 PM
hand-filer's Avatar
No it isn't.
Old Aug 16, 2013 | 04:11 PM
JamesM's Avatar
I miss the auto stop feature from my hyrbrid. Not sure why that isn't on all cars.
Old Aug 16, 2013 | 04:38 PM
FishX's Avatar
Bet it means to be transparent to the user. I thought I was pretty sensitive dirver but I cannot feel the "switch over". The only time I can sense it when getting < 35 mpg display on highway at 65 mph.
Old Aug 19, 2013 | 07:01 PM
drumultaberei's Avatar
When cruising on a plan road it works in 3 cyl, when you accelerate with the cruising controls it goes on 4 cyl and the same when cruising uphill. When you press hard on the gas it is 6 cyl. The fuel economy gauge will hint you. When it's going to the max it's 6, when moderate acceleration it's 4, when it's less then mid point it's 3 cyl.
I even cruise in the city as it automatically works in 3 cyl if the computer detects no acceleration
Old Aug 20, 2013 | 06:28 PM
imnuts's Avatar
Depending on what live data you can get from a generic OBD2 scanner, you should be able to tell what mode it is running in based on MAF readings. It would require more air to run on 6 cyl than 4 or 3 cyl. As someone else stated, the fuel economy readings would also change for the better if it is going from 6 cyl to something else.
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
joflewbyu2
Oct 8, 2015 11:16 AM
hashbrown
Sep 29, 2015 12:13 PM
