2016 RDX Tailgate Closing
Old May 30, 2025 | 09:10 AM
Anovice's Avatar
I need to pick up shower door which in the box measures 24" wide x 78" long x 4" thick and have it put inside the RDX. The 24" width does not seem to be a problem. For the 78" length, I will need to put the two back seats down. Even then, the box will hang out the back some. After it is in the car, should I push the power tailgate button (the tailgate will then rest on the box) or is there a manual way to pull the tailgate down to rest on the box which might be better?
Thank you.
Old May 30, 2025 | 11:21 PM
samiam_68's Avatar
Don't use the power tailgate. Close it manually as far as it will go and secure it with a rope.
Alternatively, you can stand up the box on its side and partially slide it between the front seats. That way, it should fit completely inside the vehicle.
Old May 31, 2025 | 04:15 AM
Anovice's Avatar
I like the idea of turning the box on it's side and sliding it between the two front seats. However, if that doesn't work, how do I close the tailgate manually?
Thank you.
Old May 31, 2025 | 06:30 AM
Kelsen's Avatar
Using your hands, place them on the outside of the door, then push down (toward the earth.)
stonebak
Apr 1, 2013 05:46 PM
djbarber
Sep 19, 2009 01:35 PM
R*D*X*
1G RDX (2007-2012)
May 9, 2009 05:16 PM
