2016 RDX Headlight Lenses
Old 04-22-2024, 07:06 PM
Anovice's Avatar
The plastic headlight lenses are starting to become hazy from the sun. Unfortunately, the car is not garaged. Is there a quick fix for improvement for a few months, if not a fix?
Old 04-22-2024, 07:09 PM
altair47's Avatar
Old 04-22-2024, 10:04 PM
alexmed2002
Alex Medeiros's Avatar
This stuff has worked awesome for me. It cleans and seals the headlight assemblies for up to a year.
Amazon Amazon
Old 04-23-2024, 05:45 AM
mrgold35
mrgold35's Avatar
Received 1,510 Likes on 1,178 Posts
I've used Paint Protective Film (PPF) on my 3 previous and 2 current Acura (living in SW and keep vehicles for +10 years). UV haze can come back even faster once you polish the HID/LED cover without some protection. PPF now comes with a 10 year warranty and can last longer. I've had good results with minimal-zero UV hazing with 3M, XPEL, and Suntek PPF on HIDs, LEDs, and fog lights.
Old 04-23-2024, 10:50 AM
Received 1,762 Likes on 1,416 Posts
The video below illustrates the the permanent 'fix' that you need, though, it may be beyond your threshold of DIY?
The following 2 users liked this post by zeta:
Kelsen (04-24-2024), TheSauceBoss (04-23-2024)
Old 04-23-2024, 05:33 PM
altair47's Avatar
https://youtu.be/Xubwpeuqm-E?si=W-Txg_WtJ_9UlIgH
Be honest, this is not a permanent solution. With proper preparation, this clear coat will only last a couple of years in the direct sun.
Old 04-23-2024, 07:06 PM
Short of throwing hard earned $$$ money away on brand new headlights, to replace fully functional ones with oxidized plastic, & from personal experience, , altair47 I would advocate it as such.
Just curious, when you talk about sun exposure, what part / state of the country do you reside in again?
The pictures below display a 'pandemic' lockdown project of rattle can spray painting my CL-S salvage yard harvested driver side front fender.
I replaced the whole fender because the previous owner stated someone had backed into it pushing the center in & it looked like he!!.
OEM quality paint matched rattle can Anthracite Metallic purchased from this website:
12 Ounce Aerosol Custom Spray Paint - Get an Exact Color Match | AutomotiveTouchup
Rattle can USC SprayMax 2K Glamour High Gloss Aerosol Clear:
Amazon.com: USC SprayMax 2K Glamour High Gloss Aerosol Clear : Automotive Amazon.com: USC SprayMax 2K Glamour High Gloss Aerosol Clear : Automotive
The rattle can Anthracite Metallic shows up darker as a result of sitting next to 18-19 year old (at the time of these pictures) factory paint.
It was not a concern because this car is a daily 'beater' and its use helps keep miles low on my rarer CL-S six speed.
The USC SprayMax 2K Glamour (which is basically the same 2K clear used in the headlight video above) has not faded / clouded or discolored in almost 48 months now of constant daily UV baking under the Florida sun.
I'd go out and take pictures of the fender now, though, it would be a waste of my time because it looks the same.
Total cost of the project including the salvage fender came in at just under one C-note.
If you ever have a 'paint' project, that you don't want to spend big $$$ on, give the 2K clear finish a try, it may just surprise you?
bpr97050
06-12-2023 05:28 PM
levonpg
2G RDX DIY & FAQ
06-25-2021 09:07 AM
Leon Korn
3G RDX (2019+)
05-05-2021 01:34 PM
acurafans
2G RDX Photograph Gallery
06-06-2015 08:42 AM
Quick Reply: 2016 RDX Headlight Lenses
