2013 RDX AC Problem
2013 RDX AC Problem
When it is warm outside and the AC is on the driver's side blows warm air regardless of the temperature setting. The passenger side will blow cold air even when the two are synced. After about 20 minute of driving while allowing the warm air to blow it will cool off. Is anyone else experiencing this?
^^ Nope....that is not normal and should not happen. You should have checked at the dealership. Keep us posted on what was the issue....I am curious
Summer is Coming
I had the problem described by the OP. AC performance slowly seemed to be getting worse and worse. Over the past week or so, the passenger side would sometimes blow cold, drivers side would never blow cold.
I took it in and it was determined that a "high side line o-ring leaking". It was repaired under warranty, vacuum tested, recharged and is working great again.
My car has a 09-2013 build date. It is certainly peculiar that an assembly or materials defect in the AC system took a full year to become a problem. ... in Texas. It cooled just fine through many 100+ degree days over the summer, many 90+ degree days last spring, and several 80+ degree days last winter. It passed their vacuum test and leak test. Hopefully it is fixed forever. If I have a leak that takes 12 months to empty the system, they'll never find it!
Maybe it had been working fine all along and loading the AC through the late August/September heat just finished off that pinched o-ring.
I'm considering a 2016 RDX once the MMC is released. A/C cooling performance is one huge question I had. Glad to hear yours works well.
Aside from hearing the compressor cycle on and off, can you feel it when driving? Does it tend to bog down the engine somewhat when compressor is on?
Can any other RDX owners chime in as to whether or not you feel that the A/C has superior cooling performance?
Do you notice the engine bogging when the compressor kicks in?
Any other issues or problems?
I plan to purchase the '16 model now that the climate control vents are in the rear.....why they weren't there in the first place has me flabbergasted.
andy
That's great to hear.
Zonian22
11-14-2015 01:20 PM
Charlespsu
09-02-2015 09:54 AM
