12v DC connectors
Shouldn't be any difference, per the manual, the total load can't exceed 10 amps on both, but you should certainly be able to charge your phone on either. Do you know if the one jack works for other devices?
I ran into something similar on a gm minivan that my customer plugs an oxygen generator into. On this one, the receptacle furthest from the driver is for accessories, the closer one is for a cigar lighter element. Upon closer inspection, the accessory one is a little deeper. I did a little more searching and found out a couple more things. The cigar lighter socket is supposed to be 20.97mm nominal size to grip the element tighter. It's also designed to heat resistant. The accessory socket is supposed to be 21.455mm nominal size, and in my experience it's also deeper.
Well, my Galaxy (wife has iphone) charges in both. We tried 3 iphone cables and all doing the same thing. Wonder if someone else with iphone is seeing that ??? I know that connection is made as some of these cables have LED on the top which is on when connected ...
Otherwise, it has something to do with the socket or the accessory's plug. I've found several things over the years that didn't fit in the socket of various cars just right. Some I could press down on or wiggle around and they'd work, but only if I held them in place.
cycdaniel
Dec 17, 2019 10:58 AM
polish_pat
Sep 25, 2015 12:24 PM
Sep 17, 2015 09:01 PM
cak165
1G TSX Problems & Fixes
Sep 2, 2015 09:21 AM
