Using ZMax
3.2CLType-princeSS
Using ZMax
I just got my '01 3.2CL Type-S a couple months ago and I got freaked out about the tranny probs that people have been having. Then one day, I was like "OH NO! My "Princess" is losing power! (CAN IT BE THE TRANNY?)" So I hit up my daddy on his cell and he places ZMAX in my hands!"
SHould I use it or should I not? cuz I hear that it actually fucks up ur engine instead of helping it. Anyone tried it before?
THANKS YOU GUYS!
THANKS YOU GUYS!
GEEZER
:killer:
Just say no to scamsters...
Originally Posted by 1killercls
:killer:
and:
http://www.ftc.gov/opa/2001/02/zmax1.htm
Excerpt:
According to the FTC, the CRC L38 test is a standard auto industry tool to measure the bearing corrosion protection properties of motor oils. In February/March 1997, an independent laboratory performed two CRC L38 tests of zMax for Speedway and Oil Chem. In those tests, motor oil treated with zMax produced more than twice as much bearing corrosion as motor oil alone. The complaint also states that the defendants fabricated one "report" from the two test reports, eliminating the bearing corrosion results and all other negative test results, and then used that report and the "official laboratory results" - similarly edited to remove detrimental data results - as sales tools in the infomercial and on the zMax Web site.
