Trans Fluid change
Old Oct 28, 2004 | 11:31 AM
JaredGMS's Avatar
Meat stick
Trans Fluid change
How much fluid is evacuated when the drain plug is pulled?
Old Oct 28, 2004 | 01:20 PM
JaredGMS's Avatar
Meat stick
anyone??
Old Oct 28, 2004 | 02:06 PM
louisn's Avatar
3 quarts.
Holds 9 quarts total
Old Oct 28, 2004 | 03:12 PM
fender4's Avatar
2.7 qts Yes I measured use http://www.amsoil.com/products/atf.html
yes you can mix it in
Old Oct 29, 2004 | 01:21 AM
JaredGMS's Avatar
Meat stick
Sorry
MODS....sorry about the wrong forum posting...won't happen again
Old Oct 29, 2004 | 04:11 PM
aclura's Avatar
all of it
Old Oct 31, 2004 | 11:52 AM
AuCLSman's Avatar
[all of it]
not true. draining the trans case is only part of a complete flush. torque converter ,oil cooler and other internal components will hold used fluid if not power flushed. take to the dealer for complete flushing.
Old Oct 31, 2004 | 07:26 PM
EricL's Avatar
Complete flush good but be careful with "power flush."
Originally Posted by AuCLSman
[all of it]
You don't need to "power flush" the tranny to get rid of most of the crud.
Most dealers will just use a repeated change procedure to "flush" the ATF. IOW, they will do a 2.7 Qt change and then shift it through the gears and change again. This process is repeated a few times until most of the fluid is "exchanged."
I would be rather careful about any "power flushing." If you're talking about hooking up to the cooler, band-aid fix lines, or other ways that would allow a complete exchange, there shouldn't be a problem IF the job is done WITHOUT cleaning solvents *and* without using pressure above what is provided by the transmission's ATF pump. IOW, the machine simply hooks into the external ATF lines and removes the old ATF and replaces it with new ATF
I would stay away from any machines that use HIGHER PRESSURES or CLEANING SOLVENTS to "power flush" the system.
Old Nov 4, 2004 | 05:04 PM
916CL's Avatar
When I changed it, I used 3.2 quartz of the redline oil and I have changed it like 4 times already
mada51589
Jan 9, 2025 04:40 PM
Aleax
Sep 11, 2015 11:31 AM
nash3222
Sep 10, 2015 09:46 PM
jfman55
Sep 5, 2015 02:55 PM
