Do new/reman trannys come with the oil jet?
Got my car back from the dealer after they replaced the tranny. I wanted check out the so called "oil jet". Where is it? I thought it replaced the fill plug. Or are they not needed on the new trannys.
Anybody have any pics?
I definitly don't have the oil jet on the replacement tranny
Either, the new one is "new and improved" or Acura is thinking "Why waste an oil jet on a car with only 25k miles left on the warranty."
I wonder if there's a way to find out?
Oil Jet Kit Information here and there and yonder.
:gheywave:
Picture of oil jet kit installed on five speed auto tranny here:
http://www.acura-cl.com/forums/showp...14&postcount=4
Acura TL / CL Oil Jet Kit Service Bulletin here:
http://www.acura-cl.com/forums/showp...68&postcount=1
Originally Posted by RooEng
.....Where is it? I thought it replaced the fill plug. Or are they not needed on the new trannys. Anybody have any pics?
Adult Supervision
so then would an oil jet help our new trannies?
I got a new one about 2 weeks ago and, if the oil jet goes into the filler hole, do not have an oil jet.
Should we all go get one?
Eric?
Eric?
Eric?
Eric?
NO!!!!
EricL-- do I get a gold star for predicting trends? <grin>
btw in answer to this:
I think I read somewhere- that the 'new' or 'rebuilt' trannies have a modification inside them that has this oil jet 'feature' whoopeeee.
If you don't need it, you don't need it ... and ....
I guess we now know where Eric stands on this.
Thanks bud.
Thanks bud.
To be clear, I'm telling you (MikeS) to NOT add the band-aid to YOUR box. If you got a replacement, and it didn't get the "band-aid," I'm presuming that they upgraded the clearances -- and or other features -- to increase the "internal" flow of ATF to the second gear assembly. I can think of a number of ways to accomplish this...
That 2nd gear fix gives me the creeps, and if you got a new box that doesn't require it, don't even think about adding the "BAND-AID."
For the record: I'd hate to find out someone avoided having the second gear fix (BAND-AID) on a transmission with worn, discolored and/or broken teeth, and then had a horrible failure -- and possible accident. If they were informed about the "band-aid" fix, and later tried to sue Acura, they would, IMO, be on shaky ground. (Hey, if you think a 5-to-2 downshift is scary, the thought of the box welding it self shut at 80 MPH with a large SUV or Semi tailgating is a real horror show.)
We're not talking rocket science here...
IBankMouse
06-13-2020 12:53 PM
