Dealership goodwill..too good to be true !?
yay! for SRS xtension
I went into Woodbine acura and told them my trans had a very rough 2nd gear engagement (also misses shifting in and out of third in SS sometimes). I am now out of warrenty (sept.00).
The parts guy (who owns a CL) got the service manager to hook me up with a goodwill replacement. He also said my CPU would be changed, and when i objected he said "well I can save your CPU and put it back in after the trans change"
This sounds a lil too good to be true
I have 86,000miles on origional trans...
should I do the replacement?
And if i use SS mode does it matter what CPU i have because i can control all the shifts can't I?? wouldnt the corolla-esque shifting only happen during D5
But i bet you can't redline first with the new CPU!!
White Type-S
Originally Posted by CleanCL
if you are smart you will take the new PCM and they will flash it with the latest firmware.
just curious..
Also this dealership has a RonJon section with his rims and a NBP TL with rons Ledgend wheels, and with the skirts it looks TOP shelf.
..they marked up your 18" servos $78 a wheel.. think i'll order mine direct ..
CHA CHING!$
I thought maybe since my car fell in the 2000 early releases that maybe my tranny was built by superman..
a transmission would cost me $2700(from dealer), i always thought it cost $4000-4500
Uses turn signals in my
Originally Posted by turbo_911
sorry for hijacking thread, but do you know how to check when your warranty expires? i have 2001 cl with 52k and still running strong...
thanks
thanks
Well...it's kinda fast...
thanks
thanks
Originally Posted by rondog
Woodbine is a really good dealership, MIke in parts helped you, huh, he has a Gold CL, right?
I totally wrote those guys off because i had an issue with the service manager over thier crap rotors.
They are back in the good book though !
CleanCL whats the advantage of the upgrade?
thanks
thanks
thanks
local Acura dealer will have the in service date of the car, just call and ask them.
Originally Posted by TCM 01 CL-S
Give the a dealership a call to find out. Unless you happen to know the build date. Some 2001's were built in 00, others like mine were actually built in 01.
so cleanCL...
..asides from the trans and chip will everything else remain the same, or will my car shift differently, and if so, can that be bypassed by the SS mode ?
..sorry for killing the questions - thanks !
so cleanCL...
brandnewcolony
09-12-2015 10:39 AM
