'98 CL 3.2: Trans fluid question
Is it ok to use DEX III trans fluid in my CL? It says in the manual to only use Honda but I know they just try to scare you into buying only from them.
no ... use Honda only .. especially if your car is that old so you have been running on OEM fluid this whole time ... it's either Honda ATF, Amsoil ATF (mine), or Redline ATF
keep it safe and just run OEM you won't be sorry
