Wheel is shaking not only braking!
Best D-Line in the NFL
Location: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Okay for a while my steering wheel shakes and I've just let it be. Figured it was balancing or something. I got new tires yesterday and balanced with the top of the line Hunter Roadforce machine. The guy said there were no complications. At higher speeds 55+ it seems that the steering wheel shakes more then it should, when I break at those speeds it shakes basically around the same amoutn maybe a little more.
I have not gotten an aligment yet but I doubt that makes a difference.
At about 15k miles I got my rotors resurfaced from the TSB. Do you think its the rotors again...and if so do you think I could get them to do it under warranty with 43k miles?
Wheel???
Could be your rotors but...
could also be a bent wheel. I had the same issue. I thought it was my rotors warping again and nope...apparently I did bend a rim. No matter how much you balance a bent wheel, it may test out ok on the machine, but if it's bent, it's bent...
That's Racist
Originally Posted by danielsmi
yeah that's the alignment. I've had that problem and just get your alignment fixed and it should go away.
does it happen more when you're accelearting? shaking in the wheel can also occur if your axle's are damaged. but it sounds more like an alignment issue.
and to answer Time for Sleep's comment, alignment isn't just about pulling the car right and left.
When it comes to alignment there is Toe, Camber and Caster. All affect tire wear, and maneveurability differently.
Enjoy:
http://www.familycar.com/Alignment.htm
Enjoy:
Moderator Alumnus
Originally Posted by Time For Sleeep
I thought mis-alignment causes the car to pull either left or right?
Sounds like he brakes too hard. Going from 110 to 15 on OFF ramps are we?
It's alright. I'm guilty too. I got my rotors turned 6500 miles ago. I'll need new rotors next and probably within 6000 more miles (LoL). I'm going slotted or cross drilled. Which ever is cheaper.
Blown is Best
Originally Posted by fuzzy02CLS
Can't be a bent wheel, the hunter balancer tests for that. It's likely the rotors. Warped rotors can cause that. There's too much run out on the rotor & it rubs the brake pads causing the steering wheel to shake. I doubt a dealer will do anything for free.
Especially if they've been turned once before. Less material makes them easier to warp.
I'm here in spirit...
Originally Posted by jproy
Id say rotors are warped. if they have been cut before, get the rotora slotted and new pads.
I still say get the alignment done before doing anything else.
might be a rotors, bent axle, wheel bearings, maybe even somthing else. i had a small rip in my outter cv boot. slung all the grease out and made the car ride horrible.
Originally Posted by Sly Raskal
didn't see that
in that case, I hope they were balanced correctly
Hahha they use the best machine in the business....you dont buy that unless you know how to balance tires.
Blown is Best
alignment will only cause the car to pull on one side or be unstable, but will never cause shaking.
a bad alignment could wear your tires not evenly and cause shaking because the tires is like fish scales, since you say your tires are new it's not the cause here.
since you just got them balanced, go back and see them, they should not charge you because it's freshly balanced and not OK.
it could be the wheel mounting on the machine, it could be some weights that unglued, it could be the tires, it could be your wheels.
we also use that $23 000 balancing machine that Honda/Acura forced all its dealers to buy, but in very rare cases, it lead us wrong.
It was like that on my last set of tires...probably a bent wheel...im 19 and don't need to be putting all this money into my car..its not really a big deal
BELAU/GUAM......
Originally Posted by rondog
last resort, bent driveshaft or conjtrol arm, thats what happened to me. vibration only when accelerating or braking, but rolling was fine.
how about vibes when you accelarate and not when rolling or braking?
mada51589
05-03-2022 08:54 PM
nuldabz
09-03-2015 05:49 PM
