Two Piston Calipers w/ 2 piece Rotors
Old Aug 17, 2009 | 10:47 AM
patricks's Avatar
7th Gear
Are there any affordable options available?
The two piece rotors from http://www.racingbrake.com/ProductDe...1%2D1&CartID=1
are crazy expensive, $650 plus $33 shipping to Ohio.
You add the SS brakes lines and and brake pads
and that total is getting very close to $1000.
Am I trying to spec someting that is not practical here?
Old Aug 17, 2009 | 11:59 AM
gnuts's Avatar
3.5 psi
search for legend calipers or nsx calipers.
Old Aug 17, 2009 | 12:05 PM
patricks's Avatar
7th Gear
I have searched and searched for 2 piece Rotors (OEM). If you can find it, by all means. Post links
Old Aug 17, 2009 | 02:34 PM
civicdrivr's Avatar
You can get 4 piece Wilwoods with 12.6" rotors and SS lines from Fastbrakes.com for under $900
Old Aug 17, 2009 | 02:42 PM
patricks's Avatar
7th Gear
Thanks civicdriver, I will check them out.
Old Aug 17, 2009 | 02:53 PM
patricks's Avatar
7th Gear
I checked the site, $825 includes one piece rotor
Old Aug 17, 2009 | 03:08 PM
94Prelude1488's Avatar
2003 Acura 3.2CL Type-S
I warped my rotors earlier this summer and after reading some threads here decided to redo my brake setup entirely w/ a little more stopping power for some fun on the mountain roads out at school.
I purchased:
NSX Front Calipers
EBC Green Stuff Pads All The Way Around
Goodridge G-Stop Lines
EBC Sport Rotors
All of the above was approximately $700 shipped which I didn't think was that bad considering all four wheels will have new parts.
Old Aug 17, 2009 | 03:36 PM
civicdrivr's Avatar
Two piece rotors are more expensive to replace. If you want them they have the $1300 kit. You gotta pay to play.
Old Aug 17, 2009 | 04:12 PM
patricks's Avatar
7th Gear
I purchased:
NSX Front Calipers
EBC Sport Rotors
Thanks for sharing your setup.
Are the rotors Slotted or straight OEM?
Old Aug 18, 2009 | 09:29 AM
Slotted and Dimpled...Here's a link to the page with the info on them...
http://www.autoanything.com/brakes/61A3068A0A0.aspx
Old Aug 20, 2009 | 04:15 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Any of you guys with the NSX calipers getting rubbing noise?
I installed my NSX calipers , raybesto rotors, and akebano pads and am getting a rubbing noise..
It seems to be there when braking and normal driving (coasting accelerating)
I think its the metal on top of the calipers..
Did u guys w/nsx calipers use that metal brkey on top of the inside caliper, if so do u get a rubbing!?!?
Old Sep 17, 2009 | 12:52 AM
wichitaone's Avatar
I did a set of 4 drilled and slotted rotors from Ebay (brakemotive) and so far they are great. I think it was $330 including shipping and with all the brake pads. I stop much better than with the stock brakes and they look great.
Old Sep 19, 2009 | 10:05 PM
OperationDarkie's Avatar
Ultra Negro
imo just do the legend/nsx brake upgrade, get some slotted rotors, and some nice pads. hell im still using stock rotors and i have 130k on my originals, no warpage yet.
I post a nsx brake upgrade in the cl forums just scroll and look for it.
Old Sep 28, 2009 | 06:15 PM
rondog's Avatar
Former Sponsor
2 piece rotors are tricky. A rotora BBK with single piece rotor will give you a decent amount of caliper clearance, but with the same caliper and a 2 piece rotor, you WILL need a 10mm spacer to clear the wheels, also you will probably rub on the fender with the needed spacer. It's pretty tricky.
Old Oct 1, 2009 | 01:48 PM
Excelerate's Avatar
Former Sponsor
This kit will be more than sufficient for what you're looking for (esp if it's a street car):
http://store.excelerateperformance.c.../i-236893.aspx
If you want a 2 pc disc you'd have to upgrade to ROTORA's 2 pc 13" kit which is about $1750 shipped.
Old Oct 21, 2009 | 04:35 PM
01RedCLS's Avatar
Can you use the stock rotors and OEM pads on the rear and focus the above mentioned upgrades on the front??
Old Oct 21, 2009 | 06:50 PM
MrHeeltoe's Avatar
Former Sponsor
Have you tried piecing your kit together here?
http://www.heeltoeauto.com/Heeltoe-B...-pr-40009.html
We discount the Racingbrake pricing on there, and add free shipping to the whole order. Worth checking out because these parts are truly awesome.
Marcus
Old Oct 21, 2009 | 06:51 PM
MrHeeltoe's Avatar
Former Sponsor
Not all the time. The two-piece rotors only need the rings replaced not the whole thing. Plus the Racingbrake parts are heat treated for longer life. They are a pretty good choice really.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
