Tein H techs?
Old Apr 11, 2006 | 01:57 PM
blkactypes01's Avatar
Tein H techs?
I just got them installed with tokico HP's, the ride is incredible, but the thing is my passenger side is slightly higher then the driver side, I know it takes a few weeks to settle. I got a wheel alignment, two days ago. did anyone have this problem with this setup. Should I wait till they settle or should I be worried?
Old Apr 11, 2006 | 02:16 PM
paulff3's Avatar
Measure the distance to the jacking points. They should be the same: left front = right front and right rear = left rear. Mine are.
Old Apr 11, 2006 | 03:54 PM
measured seem good any other ideas, you think they just need time to settle, its not like a huge difference but i can notice it
Old Apr 11, 2006 | 04:14 PM
cltypeSLOW's Avatar
Don't Mess With Texas
are the springs seated in the little rubber deals in the top? jack your car up high enough to get a jack in your well and look.
Old Apr 11, 2006 | 06:15 PM
phipark's Avatar
Not Asian
I have the Tein H-Techs and that is normal.
Old Apr 11, 2006 | 06:37 PM
bim6180's Avatar
Mine did it for about 1 day...then it's normal....make sure you're parking on a level ground ...
Old Apr 11, 2006 | 07:53 PM
ghost_masterCL's Avatar
lose some weight you fatass!!
Old Apr 12, 2006 | 12:32 PM
[QUOTE=ghost_masterCL]lose some weight you fatass!!
that was good you think that up all by yourself?
Old Apr 14, 2006 | 04:17 PM
Craptastic's Avatar
More Cowbells!
Wow, somebody a little sensitive? It was just a joke (a funny one at that).
I got the H-techs and mine were level from the start. You should ask your installer if he cut the stock bump stops the same height on both sides. Otherwise, lean on the passenger side a couple times to see if it settles.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jimmy_D
Oct 7, 2015 11:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
jmaxima03
Sep 27, 2015 10:22 AM
