Tein and camber issues
Old Jul 19, 2006 | 03:18 PM
exxtraa's Avatar
Hey i was wondering if i need a camber adjustment if i get tein basics and leave it on the highest setting and how much drop would that give me approx. i got 01 cls
Old Jul 19, 2006 | 11:15 PM
o1s's Avatar
o1s
if you set teins at their highest adjustment, you will be higher than stock i think.
Old Jul 19, 2006 | 11:44 PM
CNDC's Avatar
you will be higher than stock for sure. Also you will need a camber kit if you set the height the directions give you.
Old Jul 20, 2006 | 07:15 AM
exxtraa's Avatar
thanks, wow i never realized that tein brings you up wow.... so lets say if i drop only about an 1 inch will i need the camber kit.... also the ride with teins, whats the deal with comfort and stability... i am sure it will be much firmer which i would like over stock... also should i get comptech or hr sways... i heard hrs give you lil more, thicker right??? also i was looking at kazera or kosei wheels (18s) they are pretty damn light kazera only at 20lbs and kosei at 16lbs, what you think any other suggestions.
Old Jul 20, 2006 | 07:31 AM
exxtraa's Avatar
the reason i dont want to drop it too much cuz i live in new york and i drove like 25k a year so with all potholes ill .uck it up real quick if droped too much
Old Jul 20, 2006 | 10:10 AM
brianlin87's Avatar
ASM I.S. Design FTW.
everyone's car is different - why not install the coilovers and lower/raise(?) it to the height you want - and then figure out if you need a camber kit or not.... seems as if you don't even want to lower your car to begin with, so why not leave the suspension stock?
Old Jul 20, 2006 | 10:44 AM
o1s's Avatar
o1s
Old Jul 20, 2006 | 12:30 PM
exxtraa's Avatar
i would like to drop it but not too much right before i need a camber kit.... and then have an option in the future to drop it if i want
Old Jul 21, 2006 | 10:36 AM
Bobbydoedoe's Avatar
I'm Cool
i'm running tein ss with 2 fingers all the way around. I didn't get a camber kit because its only -.1 degress of the oem spec for the left, and the right is within the range. I guess i got lucky
TLrascal
Aug 3, 2018 11:00 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Robospinner
22
Sep 24, 2015 08:47 AM
funkbro2
Sep 21, 2015 07:53 PM
