Strut replacement
Old Oct 27, 2008 | 11:25 AM
rpopek's Avatar
Strut replacement
I have new struts for my CL-S daily driver, and would like to gather information on removal of the front struts. I have spring compressors to transfer the springs and full array of needed tools.
Fronts - I fully loosened the clamp at bottom of strut and was only able to get the strut to move 1/16". Even after pulling pivot bolt from the strut fork, and striking it with rubber mallet, not able to get this to move any further away from strut. Thought that corrosion at bottom of strut may be an issue, but the movement is too consistent on each of struts. Also thought that there may be a detent feature that is engaging the bottom of strut, just need to spring the clamp open a bit further?..... Was hoping that someone would share the process of removing the front stuts!
Also, is there an on-line site for Acura service procedures?
Thanks much...
Old Oct 27, 2008 | 11:46 AM
rpopek's Avatar
Just saw NiteQwill's excellent writeup on strut removal. This should handle any of my questions - very thorough procedure!
Old Oct 27, 2008 | 11:57 AM
LIPPSTUH's Avatar
Unregistered user
good to hear.
Old Oct 27, 2008 | 01:04 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
glad you searched.. if you have any more questions don't hesitate to ask though. maybe throw some wd-40 or pb blaster on everything you see
marcelft
Jul 10, 2018 06:17 PM
pstomps
Feb 20, 2017 03:29 AM
acurajj
Feb 14, 2016 02:28 PM
Heyzuez20
Oct 14, 2015 07:18 AM
Nicho863
Sep 3, 2015 09:16 PM
