Squealing tires
Old Jul 29, 2003 | 12:55 PM
spdy0001's Avatar
I now drive an accord....
Squealing tires
Im getting a little irratated with my tires. The car still has the stock setup with a little under 6K miles. The problem is that no matter how gentle I take off the damn tires squeal. I have checked the tire pressure and its about 35psi all around. This has only happened the last couple hundred miles. I have spun the tires a very limited amount of times and chirped second a few times, I would do it more but tire hop pisses me off. So the tire tread is still pretty much perfect.
Old Jul 29, 2003 | 01:47 PM
CO-CL-S's Avatar
Re: Squealing tires
Isn't that called poppin the clutch with a touch too much RPM? Will you be coming back with a bad clutch at 30K miles? YMMV
Old Jul 29, 2003 | 03:51 PM
spdy0001's Avatar
Ahh......I though someone would say that. Lucky for me thats not the case, as I said it has only started happening over the last couple hundred miles. Too further prove my point, I let out the clutch with just a hint of gas just so I can fully release the clutch and once I start rolling if I ease into the throttle it still does it. By doing this I have completely taken the clutch away from the problem.
Old Jul 29, 2003 | 04:13 PM
Zapata's Avatar
Cost Drivers!!!!
ugh thankfully i haven't had to deal with OEM POS TIRES since my auto CLS. I can't even imagine them on the 6mt
Old Jul 29, 2003 | 08:22 PM
ChadT's Avatar
Spectacular Aroma About
Re: Squealing tires
I know the feeling. Especially when leaving a light that's on a slight incline. It's hard to get away quickly without the tires howling in protest. The clutch takeup can be a bit unpredictable at times also. Seems like it grabs in different pedal positions. I can't wait to get better tires but I may wear these out first. FWIW if the tires are slipping the clutch is not. It's actually easier on the clutch to let it out quickly without much slippage.
Old Jul 30, 2003 | 06:43 PM
rkb007_2000's Avatar
Tire pressure?
Have you tryed dropping pressure to 32psi?
Old Jul 30, 2003 | 07:22 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Have you checked your tires??? Your alignment might be off...thus causing not enough rubber to be in contact with the road...also the OEM tires are shit..
Old Jul 30, 2003 | 07:23 PM
123's Avatar
123
lose the oil slick featured stock tires. they're garbage.
Old Jul 30, 2003 | 08:56 PM
TL_Type_S's Avatar
seriously .. just get new tires and get on w/ your life and begin enjoying REAL launches
Old Jul 30, 2003 | 10:30 PM
mt6forlife's Avatar
Just wait till it rains. My Dunlops do pretty well on dry pavement, but it takes a lot of effort not to spin through 2nd in the rain.
Old Jul 31, 2003 | 07:34 AM
spdy0001's Avatar
Ill try lowering the pressure......
I do want new tires but don't have the extra cash right now
Old Jul 31, 2003 | 07:40 AM
Smitty's Avatar
THATS THE POWER OF THE 6-SPEED BABY!!!!!.. HELL YEAH
ENJOY!!!... your a badass now!!... hey I got 4 stock tires in the Blackmarket for sale...LOL..
Smitty
Old Jul 31, 2003 | 08:52 AM
spdy0001's Avatar
Originally posted by Smitty
your a badass now
Old Jul 31, 2003 | 10:02 AM
phatpat's Avatar
when you're in the market for high performance tires, i recommend toyo proxes t1-s
Old Jul 31, 2003 | 10:44 AM
civic4982's Avatar
SHIFT_over.so.I.can.see
I've got some brandnew Bridgestone Potenza S03s I'm thinking about selling. Check the "back to school SALE" in black market.
Old Jul 31, 2003 | 12:42 PM
GreenMonster's Avatar
I've got a completely stock 6spd and I have problems too with the shitty tires squeaking too. It only happens when I'm on the gas a little bit too much tho'. If I drive like a grandfather it's quiet
Old Aug 1, 2003 | 11:13 AM
NarTaX's Avatar
I can roll in first gear, punch it, and it will start squealing when the secondary intake runners open up.
DidiBob
Jan 4, 2016 12:41 PM
2012wagon
Sep 29, 2015 04:21 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
