spring seats
Old Jan 15, 2008 | 08:51 PM
MADMAN187's Avatar
spring seats
I am installing H&R springs with kyb gr-2 struts. I read the DIY on the spring/strut installation and noticed I need to get a set. Can someone help me out and tell me where to get the compatible aluminum spring seats for the kyb's???
Old Jan 16, 2008 | 03:25 AM
Nutshell's Avatar
aluminum seats? the springs will fit fine, i had the same setup on an accord. im also about to put this setup on my cl.
Old Jan 16, 2008 | 07:28 PM
MADMAN187's Avatar
So theres no need to buy new spring seats correct? Did you like the setup?
Old Jan 17, 2008 | 02:15 AM
Nutshell's Avatar
no i dont believe youd need them.. i just had the springs and struts and they were great. kept a nice firm ride over oem but it didnt break my back.
Old Jan 19, 2008 | 12:29 PM
MADMAN187's Avatar
Alright I installed them yesterday and they ride beautifully. I just have a clunk sound comming from the passengers side shock. Anyone had this problem???
Old Jan 19, 2008 | 01:02 PM
Nutshell's Avatar
when does it happen, over bumps, at braking...and is it just a one time clunk each time or are there several at once..
Old Jan 19, 2008 | 01:59 PM
MADMAN187's Avatar
It only happens over bumps if I dont slow down too much. It sounds like metal contact
Old Jan 19, 2008 | 06:18 PM
smooth CL-in's Avatar
Registered CL-er!
Wereu refering to those rubber pieces that go around the top coil?
First off front or back or both? Did you remove your RSB bolt for more leeway? If its loose than it will make noise when going over bumps. i had that problem and replaced the bushings. They were too worn to tighten.
Old Jan 19, 2008 | 06:51 PM
MADMAN187's Avatar
Its only the front drivers side shock. Which ones the RSB bolt?
I think I said passenger's side on the other post. I meant the driver's side
Old Jan 19, 2008 | 07:23 PM
Registered CL-er!
well, FYI rsb= rear sway bar. I know in the DIY right up. It suggests to remove the bolt so the sway bar can drop down, giving way for the shock to come out, but the problem is in the front.....
Are the shocks new? Is there alot of bounce in the front?
Make sure all bolts at the strut mount are tighten. Get someone to bounce the front of the car while u look underneeth. See exactly were its coming from.
Old Jan 20, 2008 | 03:17 PM
MADMAN187's Avatar
I checked it out today and re-checked the tourque settings on the bolts. As I was loosening the 12mm bolt thats on the strut bar and it cracked instantly. I ordered a new top hat and it will be replaced. Il get back on this after replacement. Thanks for the help!
Old Jan 23, 2008 | 06:40 PM
Registered CL-er!
no prob.... good luck..
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
