spacers
spacers
i really want to put my rims back on so i think im going to run some spacers. my question is becuase i might be getting some from a guy i know. if therer not hub centric will that be a problem?
Whats up with RDX owners?
I would stick with hub centric spacers (64.1mm) just to keep vibrations down.
What do you mean? The thread pitch?
H&R spacers should come with new studs. I bought 10 mm and had to install the the longer ones.
Measure the center bore of your aftermarket wheels before you buy hub-centric spacers. I bought the appropriate size for my car, but my Work wheels have a larger center bore and it doesn't touch the hub-centric rings at all. I do have vibrations in the steering from this.
EDIT: I bought mine from Options Auto Salon. 10mm require longer studs which come with the spacers.
Ichiba
http://www.optionsauto.com/products.asp?dept=9604
H&R
http://www.optionsauto.com/products.asp?dept=9377
Ichiba
H&R
IMO Id run longer studs if you are running 5mm or larger spacers.
Works have a 73mm hub bore IIRC. Stock is 64.1mm.
Same 73mm IIRC.
The thread pitch is 12x1.5 but I have no idea how long they are.
so the real question here is how does the ichiba v2and others like it work? you bolt it on your stock lugs i know that part but the stock lug sticks out... so how would your wheel fit on the spacer? wouldnt the lug be in the way? would you have to shave the stock lug down or is it just simple and easy.. bolt spacer on then just put wheels on? sorry if this is a noob question
Most wheels have webbing on the pad:
The stock lugs fit into that empty space. Might not work for all wheels though.
Im not the one to ask for spacers. I dont like them, so Im a bit biased.
The Ichiba spacers have built in studs IIRC. The whole appeal to them is you dont have to replace your stock lugs.
No kidding, wish I knew that. Replacing the studs isn't that bad. Took about 45 minutes per side with air tools. If Ichiba makes it that easy, that's the way to go.
Might have better luck in the 3G section. I dont think many people run spacers over here.
rockvilleTL
09-19-2015 04:44 PM
