Performance gain from lighter wheels??
Old 06-10-2004 | 11:32 AM
TypeSDriver's Avatar
Hey guys, I'm getting ready to get rid of my current setup in favor of something that is MUCH lighter. I currently have chrome '03 CL-S wheels on my TL-S with 235/45/17 Sumitomo HTR+ tires. This setup weighs approximately 52 lbs per wheel/tire.
Now, what I'm looking at getting are the new Konig Trouble wheels in the same size as the CL-S wheels (17 X 7). Each rim weighs 19 lbs, as compared to 26 lbs for the CL-S wheels. Also, I believe I'm going back to stock size tires as they are lighter and I don't believe I'll lose much cornering ability. I'm going to get the Falken Ziex ZE-512 tires, which get really good reviews and are one of the lightest tires available.
So I'll be going from 52 lbs per corner to 40.4 lbs per corner, resulting in a 11.6 lbs savings per wheel/tire. What kind of performance gains can I expect from this much weight savings? Handling, acceleration, ride...etc Thanks in advance...
Old 06-10-2004 | 11:46 AM
kevin79925's Avatar
:search:
and the answer is not much. .1 off the 1/4 for 50lbs savings maybe
Old 06-10-2004 | 11:52 AM
NiteQwill's Avatar
Adventurist.
Acceleration will improve somewhat d/t less rotational mass, you should also see an increase in MPG. Ride will be the same, running the same tire size. Handling is somewhat improved, not much, it all really depends where the weight of the wheel lies... inner, outer, center.
Old 06-10-2004 | 12:09 PM
EricL's Avatar
Please use the search engine...
THE SEARCH ENGINE IS YOUR FRIEND! Try searching on: "lighter wheels" and/or "rotational inertia"
It depends on the construction of the wheels!
You could end up with an equivalent reduction of static weight close to reduction in wheel mass (if weight loss was concentrated near the center of the wheel/rim).
So, example: If the tires are the same, rim diameters the same, but the verymost inside of the wheels weight 2 lbs less per wheel, you would have 8lbs less weight and you could just subtract this from the car's weight and reconvert your power-to-weight. (3500 - 8 = new weight). You then figure your new power-to-weight.
Do the same thing -- as shown above -- but with 3X times your weight loss per rim to find the upper bound of possible equivalent static weight loss.
There is no such thing as HP gain from loss in rotational inertia or loss in static weight.
The outside of a wheel is moving with a rotational component and translational component. The inside of the wheel is moving at the same speed as the rest of the car (it's call translational motion).
IF the "bulk" of the tire/wheel weight were concentrated at the outside of the wheel, the "effect" of this weight loss would be close to 3x.
The max equivalent gain is close to 3X (So, if you lost 60lbs from tires and wheels you could consider that to be 180lbs of lost weight from the car at the most). If that same 60lbs was only "lost" at the inside of the wheel, the gain would only get equal to 60 lbs. Take the weight and subtract it from the car’s weight and plug in the NHRA acceleration calculator and that’s about as close as your going to get without getting into some real work.
Every wheel is made differently, so there is no such thing as getting xx HP from xx lbs of lost wheel weight.
See the following picture:
LINK: http://dept.physics.upenn.edu/course...on4_1_4_3.html
The wheels and tires on a vehicle are translating at 1x car's velocity and the outside is rotating at 2x car's velocity); this makes for a possible upper bound in equivalent static weight going of 3X (1x + 2x).
Without knowing the construction of the tires, exactly how much they weight, you are going to be guessing and so is everyone else.
The Toyos + SSR competitions vs. stock were about 38lbs/wheel vs. 52lbs wheel tire stock. That's close to 60lbs. The rims were forged and the outside are VERY light. The tires in the 235/45-17 were 2-3lbs lighter than the stock tires. The net effect was like having one less heavy passenger or throwing out two light people.
You might very well lose enough traction from going back to the thinner rim and tire to negate any weight advantage. Finally, the different tires have different drag losses. IOW, you could actually lose performance. When you change more than one thing at a time, you are really making it very difficult to chart what gave gains or losses.
Old 06-10-2004 | 12:13 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I would like to see some dyno charts of light weight wheels compared to stock!
In principle, there should be gains or loss... but let us say if it is less than 1-2%... does it matter?
Old 06-10-2004 | 12:35 PM
NSX-Tuner's Avatar
boosted is best
I would expect a slight increase in WHP with lighter wheels and/or brakes. Doesn't rotational mass (unsprung weight) from the wheels, brakes, etc... slightly reduce the amount of power delivered to the ground?
Old 06-10-2004 | 12:40 PM
typeR's Avatar
i recomend going 225/45 in favor of the 215/50
Old 06-10-2004 | 01:04 PM
EricL's Avatar
1-2% (who says?) And for a busted down Buick or a race car?
If you’re 80-years old and own a old beat up Buick: NO!
If you ask that question around a F1 paddock … well, good luck.
See above and if you add up a bunch of 1- to 2-percents it matters quite a bit. BTW, if you calc in about 60x3 = 180 for equivalent static weight, then take the car weight around 3600 lbs, you're talking about 3600 / (3600 - 180.0) ~= 1.05 (around 5 percent gain).
And, when you use an inertial dyno, you are going to test only two of the wheels against the weight of the drum -- and not the weight of the car. So, if you're driving a heavy-ass car, your gains will probably be minimal. If the car is lighter than the drum, the gains will be greater. And, a drum is not going to replicate tire deformation on the street.
Why do you think Porsche uses hollow spokes? And, why does the NSX use titanium connecting rods?
Next time you toss a passenger in the car, who weighs about 200 lbs, see how your 1/4 mile times are.
One of the reasons people SHOULD put light weight wheels on their car is to reduce unsprung weight. The car rides much better and handles better with the tires staying in contact with the road. When you have heavy wheels, you end up using the tire's material and air inside it as a secondary spring and it doesn't do too well with a heavy-ass wheel. Take some heavy wheels and go over some "sloppy" section of pavement and then put some light ones on.
Another reason is: lighter load on the engine and TRANNY. If you lower the weight of the car or the rotating parts on the BACK end of the transmission, you’re lowering the load on it. It may be a few percent, but that is quite different from adding more HP/TQ and increasing the stress for performance gains.
Another reason is: better gas mileage.
BTW, have you forgotten all of the "Why is my 1/4 mile time so bad" from the folks that put on larger chrome wheels!
Old 06-10-2004 | 01:18 PM
EricL's Avatar
Unsprung weight != rotational inertia
Unsprung weight != rotational inertia. Related – yes. Same thing – no.
If the part is rotating: rotors, wheels, tires, etc -- it will impact the rotating inertia. The more the weight is moved outward, the more it impact performance. The radius is very important as the effect is related to radius^2.
Unsprung weight is all of the weight (including some or the actual spring), that is on the wheel end of a spring. IOW, the brake calipers, brake rotors, pads, suspension parts (generally some percent of their weight depending on what they are), wheels, brakes, etc.
For example, the static weight of a tire and wheel can be put on a scale and that will give you the unsprung weight. Same with the brake calipers.
You get better handling and tire contact with lower unsprung weight. It's easier to "damp" a light tire and wheel that a really heavy one. If you have a lot of unsprung weight, the tire's sidewalls (along with the air inside it) is working as a spring/shock between the road surface and the wheel.
Old 06-10-2004 | 01:41 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
I used to switch wheels all the time on my Accord. My aftermarket setup was about 10 lbs. heavier per corner and it made a HUGE difference, most notably in braking! Acceleration also dramatically improved as well as ride and handling. AND I'd get 2-4mpg better with the stock wheels on. I will never buy heavier that stock wheels ever again!
Old 06-10-2004 | 01:43 PM
EricL's Avatar
Braking improved -- yes!
Good point!
Old 06-10-2004 | 01:52 PM
fuzzy02CLS's Avatar
My SSR/235-45-17 tire setup weigh in at 38lbs each. I saw a difference in ride, handling, braking, & speed. Does it improve 1/4 mile? Comon sense says it should as well as dyno #'s. I really don't know though.
Old 06-10-2004 | 04:02 PM
darrinb's Avatar
///M POWER
i would do a before after dyno
Old 06-10-2004 | 04:42 PM
NSX-Tuner's Avatar
boosted is best
Thanks for clarifying this. This is especially important to me since I'll be soon upgrading to lighter wheels (18x7.5, 17 LBS ea.) and stickier tires (235/40ZR18). I'll also be upgrading to a big brake kit. I'm guessing that what I save in weight on the lighter wheels, I'll gain in weight on the tires and big brake kit. So at worst I'm hoping to be a wash as far as any gains/losses.
Also, I'll be getting a dyno shortly afterward to compare to my previous dyno.
mantis23's Avatar
Moderator Alumnus
speaking of lighter wheels, I bought 2 SSR comps from a local guy who had them on his TL. 100x5 is printed on the actual rim. Our bolt pattern is 114x5 or something like that. Will the 100x5 bolt pattern work on the CL? He had taken these off of his TL, so I figured they would fit.
Old 06-10-2004 | 04:48 PM
fuzzy02CLS's Avatar
I have the before, Need to do the after still.
Old 06-10-2004 | 05:39 PM
Louie11's Avatar
Turbo mag. Did this test on a civic hatchback. The car had 15's on it and they plus sized it to a 17" set up. The overall diameter was raised by an inch or so, but the weight was raised 10-11lbs. They dyno'ed the car with the stock set up and then with the plus sizing. Adding 10lbs to the wheels made the car lose 6hp and 4lbs of torque. so I don't know if it works in reverse, that you will gain the same amount by subtracting 10lbs.
Old 06-10-2004 | 05:44 PM
RUF87's Avatar
Lead Footed
Ok, first as EricL says, there is no gain in HP. However, because the set up weighs less it doesn't require as much HP to turn the wheels and tires. Also, what EricL says about where the weight variance in terms of near the center of the hub. Basically the further the center of the hub that you reduce weight, the greater the benefit. So, tire weight is more important than wheels, but note that each wheel design has an impact as well. Some wheels may have more weight towards the outside than others.
So what's it all worth. Based on my personal experiences, wheels and tires can be equal to the gains of a CAI or headers. My claim for this is that at the track my TLS with 18.2lb wheels and 20.8lb Toyos was running with and even beating guys with headers or CAIs. I'm not talking about beating them in a heads up race, but was beating their times.
Don't over look it is all I got to say.
Ruf
Old 06-10-2004 | 05:46 PM
car_lost's Avatar
dont know if they'll fit... but the bolt patter for our cars is definitely 5x114.3 i believe. only way to see if it'll work is to test fit them... seems doubtful to me though.
Old 06-10-2004 | 05:47 PM
RUF87's Avatar
Lead Footed
Mantis, I think the TLS and CLS have the same bolt pattern. We'll have to try them out and if they don't work I'll just have to take them off your hands. :P
Maybe we can try at the cooling mod meet to see if they work.
Ruf
Old 06-10-2004 | 05:53 PM
RUF87's Avatar
Lead Footed
BTW - I did a dyno with the wheels and tires and the numbers did not change from what I could tell. But my 0-60 times dropped 2 10ths and my 1/4 mile times were in the 14.65-14.75 range . . . a 2 10th improvement and with no other mods.
This would indicate that the biggest impact is on the lowend . . . which means once the tires are turning then it's not that big of a deal anymore.
EricL, that would make sense . . right?
Ruf
Old 06-10-2004 | 07:50 PM
Thanks to everyone for some great advice. It sounds like I'm going to be pretty happy with the added performance all around this lighter setup is going to give me.
These are the wheels that I'm getting...what do you guys think?
Old 06-10-2004 | 10:04 PM
car_lost's Avatar
nice choice!
Old 06-10-2004 | 10:35 PM
mattg's Avatar
nice looking wheels.
Old 06-10-2004 | 10:39 PM
Ant7701's Avatar
Sweet as Gold
those wheels are hot!!The also offer those rims in black w/ the center of the spokes polished...and they also have those same rims w/ seven spokes instead of five. Get someone to photoshop all of them on ur car before u make ur decision.
Old 06-10-2004 | 10:45 PM
Sturm's Avatar
TSX Bronco
Good choice in wheels! Here's some pics of my TSX with them
Sturm, who's a former '01 CL-S owner
Old 06-10-2004 | 10:52 PM
mattg's Avatar
^ they look very sporty on your TSX.
EricL's Avatar
Ruf
I think so…
Inertia is inertia. Depending on the engine, you might see more "effective" gain at different speeds. Some ECUs will respond well to lighter load, and lighter wheels are equivalent to going downhill. If the engine is in an area where it is not getting a lot a intake velocity charging, the effect of going downhill, losing weight by chassis lightening or reducing rotational inertia can have a more pronounced effect. (There can be some "synergy.") So, you could very well be noticing a more-subtle aspect...
You will get the gains evenly in different gears -- unlike the pulleys that give you more punch in lower gears. The wheels and any spinning parts on the backside of the transmission will not be affected by "reflected load" issues that show up with engine-side lightening. For example, if you lighten the flywheel, crank pulley, or con rods, you're going to get a greater effect in lower gears. A good book control systems will explain this.
When the car reaches the end of the 1/4 mile, the bulk of the drag force is from aero effects. A lighter wheel would have little or no impact on top speed (the aero drag being related to velocity squared.)
I haven't run any 1/4 miles at any strip. However, the Gtech times are MUCH lower with the wheels. With Comptech headers, AEM intake, 60-70 F, 1/4 tank, the car does around 5.7 seconds to 60. When colder out, it goes even faster.
The day I drove out of the shop with the SSR Comps, I noticed an acceleration difference instantly. I noticed it at all speeds (then I got used to it). Since I was taking it easy on the tires, I didn't mash the pedal, but the car needed much less throttle input and gas mileage was better from that day forward.
When I first got car back with the intake and headers, I noticed a BIG difference from 5K and up.
When I first got the car (stock), and it was properly broken in, the 0..60 second times using the same gas, load, etc was 6.4 seconds.
I've been next to 540Is, 350Zs, and a few other cars and the owners were surprised. And, before this gets into a pissing content, I talked with some guys after we "played" and had a nice chat and enjoyed each others cars. The two had manual trannies and we weren't trying to run people off the road -- END.
Old 06-10-2004 | 11:48 PM
darrinb's Avatar
///M POWER
who has done before/after dynos on lighter wheels??
Old 06-11-2004 | 08:15 AM
RUF87's Avatar
Lead Footed
I think so…
Thank EricL,
I'm pretty sure I followed most of that . . . it makes sense.
. . . and yes, I experience the same thing when accelerating from a stop . . . much easy to spin the tires . . . which made launches a bit trickers. :P
Also, I agree with the experience you had with the 540's and 350's . . . I've surprised a few people myself . . .
Ruf
Old 06-11-2004 | 10:04 AM
mantis23's Avatar
Moderator Alumnus
blxmjx did.
he claimed a 10 HP increase when using lighter wheels on the same dyno day.
don't remember the diffrences in weight however.
Old 06-11-2004 | 10:14 AM
NSX-Tuner's Avatar
boosted is best
blxmjx did.
Well in a couple of weeks, I should be able to report back on dyno results after I get my lighter wheels on. Not that I would expect it, but another 10 WHP would be nice.
Old 06-11-2004 | 10:19 AM
mantis23's Avatar
Moderator Alumnus
here is the post where he said he gained 12HP
http://www.acura-cl.com/forums/showp...0&postcount=20
Old 06-11-2004 | 12:26 PM
EricL's Avatar
Pretty reliable fellow. Those were light wheels, but they were also 19". The size negates some of the weight loss.
If he hadn't doubled that actual dyno gain by 2, then the "equivalent gain" is actually 24HP. (The back wheels are not spinning on the dyno, and their inertia is just as important as the fronts.)
So, if someone was trying to relate the HP to dyno roller weight, you'd need to multiply the 12HP by 2 for the equivalent gain from an engine mod.
So, presuming that is correct, that would be 24HP, and that is almost a 10% gain.
As I mentioned, some care should be taken when using this value. The inertia is being compared against the weight of the roller(s)/drum(s) -- and not the car.
Old 06-11-2004 | 12:29 PM
typeR's Avatar
eric i question that logic though because HP on a dyno is relative ...his other dyno never showed the HP loss from the original rear wheels because they were never measured...thats why i never really cared about dynos ...take it to the track...thats the gain im looking for
Old 06-11-2004 | 01:29 PM
EricL's Avatar
Delta == change needs to be considered. Presuming change is uniform at front & rear.
CHANGE (delta) in inertia is always the same. Just because the rotors or other parts in the rear are different doesn't impact a change. As long as the tire/wheel combo at the front/rear is identical, the results would need to be multiplied by 2. If you can make a case for the wheels not being in contact with the road, that would be different.
If someone wants to play "armchair HP vs. inertia tech-wiz," they need to consider that unless you're on a 4-wheel dyno, you're only going to get the "presumed" gain or loss from only two of the wheels. IOW, you need to multiply by two (that assumes that all the tire and/or wheel modifications are identical).
If you do a FWD car on a two-wheel dyno, you will never see the results from the changed rear wheels.
If you do a RWD car on a two-wheel dyno, you will never see the results from the changed front wheels.
If you have identical tires and wheels in the front and back -- as is the case with most FWD cars -- you will lose or gain the same amount of inertia (FRONT and BACK) from a given change (this presuming that you change ALL four wheels/tires and the change is uniform for all four wheels and tires!
If you do a RWD dyno on a newer RWD car, the 2x factor would be USELESS, since most of the newer RWD cars have bigger tires and wheels in the rear. (Not all of them, but most of the high-performance sport models do). In this case, it would be pure guesswork to figure out what you were getting. At best, it's a number to toss around.
RE: track – yes.
It would be best, of course, to just find out at the track. This presumes that you have similar track conditions (same track, same temp, humidity, gas load, etc.)
02-25-2020 09:57 AM
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
Quick Reply: Performance gain from lighter wheels??
