Opinons needed for the lightest wheels that fit the CL
Whats up with RDX owners?
Light dont come cheap. How much are you looking to spend?
Motegi Traklite 2.0
Enkei RPF1
WedsSport TC 105N
SSR Type C or F
Gram Lights 57 Extreme
Volk Racing TE37SL Super Lap
Enkei RPF1
WedsSport TC 105N
SSR Type C or F
Blown is Best
Also take a look at OZ wheels. Some are 14 lb wheels and they are known for their strength/construction
Take a look at Tire Rack and you can search for wheels for the CL and sort by weight.
^ I love them, its just a shame that these fucking VA roads cracked one of them
Let me get at least one fact straght.
Is it true that every pound removed from the rim/tire is like stripping off 20 pounds of weight from the body?
If that's true my current wheels weigh a touch over 20lbs with out tires.
So a 15lb wheel without tire would be like taking off 400lbs ?
Some one please correct my math here ,because those gains sound retarded to me.
And that's not even including a lighter tire if droping down to a 17" setup.
Rotating mass is nothing like static weigh. The benefits of running lighter wheels are exponential.
However, one downside is they are easier to spin. You have to really work on your launches.
Other things would be like pulley, flywheel, rotors.
Here are 2 links with info on it.
http://www.twothongs.com/Articles/Ro...nsprungWeight/
http://hpwizard.com/rotational-inertia.html
You can also read what inaccurate posted about it in his diet thread. It is post #143 on page 4.
https://acurazine.com/forums/showthr...=610974&page=4
Unregistered Member
Either way, that's just a rule of thumb. The TYPE of weight is different, so it's not just a simple conversion. However, I can definitely say that less rotating mass can make a big difference.
Former Sponsor
Don't forget, lighter wheels will also take away a little of that highway cruising length, the car will tend to slow down a bit, almost like a lighter flywheels. And traction will be more of a problem unless you counter the lower weight with a wider or sticker tire contact on the ground.
Our Legend in 18" x 8.0" is a perfect fit and weighs about 22.5 lbs each, much lighter than the OEM 17" x 7.0" wheels which weigh about 25 lbs each.
Expense is also a factor obviously.
Personal preference. 17s through 20s will fit. Though 20s look ridiculous.
gotjnco (05-07-2012)
Meh. Who wants 16s?
gotjnco (05-12-2012)
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
nuldabz
09-03-2015 05:49 PM
