offset question
offset question
If i have right now a 19x9.5 +40 and added a 25mm spacer, can i get a 19x12.5? what offset would i need?
for the front i have a 19x8.5 +40 and added a 25mm spacer. can i get a 19x10 in the front without any issues while turning? what offset can i go with?
thanks in advance
thanks in advance
How much clearance between the wheel and the strut do you have when the wheel is mounted? I know you have the fender space since your widebody, but your asking for a 3" wider wheel in the rear, its hard to guesstimate an offset without knowing how much clearance you have behind it.
You can go to a 19x10.5 in the back at ~+27mm and the outside lip of the wheel will sit at the same spot as your current wheels, with the remaining width of the wheel making up the difference of the spacer you are currently running. Find out how much space you have between the wheel and the fender (with spacer) and the wheel and the strut (without spacer) and we can figure out what offset to go with.
As long as my math is correct, you can go an inch wider in the front as well (19x9.5 +27mm) and it will do the same as the rear. But again, its hard to figure out without knowing how much space you have to work with.
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
