offset question
Old Mar 29, 2011 | 09:00 PM
krazykrnboi's Avatar
Wide Body 3.2 CL-S
offset question
If i have right now a 19x9.5 +40 and added a 25mm spacer, can i get a 19x12.5? what offset would i need?
for the front i have a 19x8.5 +40 and added a 25mm spacer. can i get a 19x10 in the front without any issues while turning? what offset can i go with?
thanks in advance
Old Mar 30, 2011 | 01:03 PM
civicdrivr's Avatar
How much clearance between the wheel and the strut do you have when the wheel is mounted? I know you have the fender space since your widebody, but your asking for a 3" wider wheel in the rear, its hard to guesstimate an offset without knowing how much clearance you have behind it.
You can go to a 19x10.5 in the back at ~+27mm and the outside lip of the wheel will sit at the same spot as your current wheels, with the remaining width of the wheel making up the difference of the spacer you are currently running. Find out how much space you have between the wheel and the fender (with spacer) and the wheel and the strut (without spacer) and we can figure out what offset to go with.
As long as my math is correct, you can go an inch wider in the front as well (19x9.5 +27mm) and it will do the same as the rear. But again, its hard to figure out without knowing how much space you have to work with.
Old Mar 31, 2011 | 09:34 PM
Wide Body 3.2 CL-S
alright. thnx ill make the measurements next week when i put the new tires on. thnx
Old Mar 31, 2011 | 10:41 PM
rondog's Avatar
Former Sponsor
We got single piece monoblock forged wheels with 13" width, any custom offset and finish, even custom designs, holla at me and I'll give you the scoop.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
mellsonnj
Sep 24, 2015 04:42 PM
