New Rims offset question
Hey guys,
I have a question.
Will 18"x 7.5" rims,5 x114.3, with a +42 offset fit my 2003 acura CL- S?
I am using the factory rims with snow tires and want to use a new rim with summer tire. I really need to have the abilitiy to take off/ put on tires between seasons.
Let me know your thoughts about the offset and what I can do about it.
thanks
I have a question.
thanks
My Work is Done Here
1 Post
Shouldn't be a problem. I know it's not a problem on the 01's, they can handle a 42 offset fine (a slight rub here or there depending on the load, ride height, and driving style), and I don't believe there is anything different with the 03's.
Originally Posted by 1bigredviper
Hey guys,
I have a question.
I have a question.
You might rub if you drop the car.
I’m running 18” - 7.5 wide and +48 offset.
I have TEIN coilovers on the car and it isn't dropped too radically.
i have 20x7.5 with 42mm offset and my car is dropped 2.25 inches all theway around i get minimal rubbing only when ihave a full load and i am making a hard right turn only i think you should be fine
as for the rubbing issue, you may experience some rubbing if you don't roll the fenders... +42 or +43 is a little low but will fit. If you can get a +45 get it, but if you get a stellar deal and don't mind rolling fenders, run with the +43.
still a Masshole
42 is close but will only rub occassionally. I have a TLS with 18x7.5 and a 42 offset wrapped in 225 tires and I rub on occassion. I might be getting 235 tires so I know I will rub. Oh and I am stock height...unforeskinitly!
nuldabz
09-03-2015 05:49 PM
