New Mods
New Mods
First off, where do we talk about performance mods? On the TL forums? Anyways I just got the 60 degree stat, P2R intake manifold gasket, and the P2R throttle body spacer. My question is did I waste my money? Or not really? Also, the spacer didnt come with any gaskets for each side, do I get oem gaskets or the P2R gaskets?
You did not waste you money but you are not going to feel a increase of performance with those mods with out combining others.
Get 2 p2r TB gaskets for your spacer.
To go with your new Tstat you should get a lower temp fan switch and a higher pressure radiator cap.
You want performance you can feel get pulleys,headers,intake.
2ndgentl
Yeah I already have comptec intake, headers, exhaust, deleted cat, im just trying to get a little more out of my car. Im about to do my timing belt/water pump, should I get a set of pulleys? Crank/alt/ps. If I do I wouldnt get the underdrive pulley, just the lightened stock diameter pulley so I wouldnt have to buy another belt. But they do sell all the pulleys lightened, I know the crank pulley would make a difference but would the alt and p/s do anything?
The alt/ps/ac pulley is more for looks. The crank pulley is the one you will notice.
You wont feel anything from the tb spacer. As RP said, make sure you get a higher pressure rad cap and a cooler fan switch to go with the lower temp tstat.
And for performance, you can post in the general area. We dont have a dedicated performance subforum.
i bought the intake manifold spacer, throttle body spacer with dual gaskets(all P2R) and cleaned out my intake manifold and didnt feel a bit of difference at least at first. after a few days it seemed to have a little better response, but it did make my intake quieter
I CONCUR WITH YOU ^^^
OH and as far as pulleys go, if you are doing the timing belt, then go ahead and do all the pulleys while you are in there. Yes, the crank alone is the main source to free up power, but if you do all of them supposedly you see an even more gain. But if you didnt do the crank and just did the accessories pulleys, then you really wouldnt tell...
Edit by Admin Ron A:
This is not only not the best place to post, it is the worst possible place to post your sale.
Please wait until you are eligible and post in the correct forum.
I sent you a PM. Watch for it and reply when you get it.
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
lanechanger
Oct 13, 2015 10:56 AM
