New CT Springs are in
Old 09-28-2004, 10:49 PM
Blown is Best
Allout's Avatar
Installed the new Grey Comptech Springs this weekend along with a set of Tokico Illuminas and SPC Camber Kits.
Here's the Before picture with Stock springs and struts:
A shot of the Rear Struts:
And here's the After:
Old 09-28-2004, 10:57 PM
Adventurist.
NiteQwill's Avatar
Very nice! Seems like CT got rid of that raked look....
Old 09-28-2004, 10:58 PM
sidemarker's Avatar
why did you waste the money for the spc camber kit???
i have the the same set up as you with no camber issues at all...
sidemarker
Old 09-28-2004, 10:59 PM
sidemarker's Avatar
hmm did comptech drop the rear some more???
sidemarker
Old 09-28-2004, 11:00 PM
Adventurist.
NiteQwill's Avatar
SPC kit is nice for adjustability, you can always crank out the kit to the negative degree before spirited driving, then go back to OEM specs.
I too never need a camber kit, but it would still be nice to have one also.
Old 09-28-2004, 11:05 PM
Blown is Best
Allout's Avatar
sidemarker
I'd rather have the ability to dial in the settings. Set the front to -.70 Camber and rear to -.50. I may have dialed in too much rear negative - feels a little tight in the rear. I'm going to let it settle a bit before I change it though. There's a lot of room to play within the settings with +/- 1 degree.
Old 09-28-2004, 11:06 PM
Blown is Best
Allout's Avatar
As usual - you're thinking.
Old 09-28-2004, 11:07 PM
///M POWER
darrinb's Avatar
lookin good, looks like an eibach or hr drop
Old 09-28-2004, 11:08 PM
Blown is Best
Allout's Avatar
sidemarker
Here's the drop I got:
1.625" (left front) 1.750" (right front)
1.375" (left rear) 1.375" (right rear)
Old 09-28-2004, 11:13 PM
sidemarker's Avatar
interesting i never knew you could adjust the camber like that. so when the new springs settle are you going to get an alignment? how easy is it to adjust the camber?
dang comptech really did drop the cl-s some more. if im looking at the numbers correctly that should still have a rake effect. but from the pics it looks pretty even
sidemarker
Old 09-29-2004, 01:21 AM
13.2 @ 104.76mph
bigguyonbike's Avatar
that's a pretty even drop. nice !
Old 09-29-2004, 01:22 AM
mattg's Avatar
looks nice, congrats.
Old 09-29-2004, 02:22 AM
TranceFusion's Avatar
looking good.....
Old 09-29-2004, 06:18 AM
typeR's Avatar
much better...but when you say grey? those look black?
Old 09-29-2004, 08:19 AM
Not Asian
phipark's Avatar
and what do you mean by 'new'?
Old 09-29-2004, 08:50 AM
Adventurist.
NiteQwill's Avatar
By new, maybe he means they fixed the "rust" problem.
Old 09-29-2004, 08:53 AM
fuzzy02CLS's Avatar
Where are the rubber things that go on the springs for noise.
Old 09-29-2004, 09:22 AM
hemants's Avatar
Nice Comptech Pro Kit. Rear looks a tad saggy but not too bad. Definately would sag on the heavier TL though.
Old 09-29-2004, 10:37 AM
Spectacular Aroma About
ChadT's Avatar
Those are the new Eibachs Comptech is selling now. I like them on my car but I adjusted the rear Konis up a bit to get rid of the droopy-butt. Seems like a much better spring. Car is much tighter than with the old Comptechs.
Old 09-29-2004, 10:40 AM
fuzzy02CLS's Avatar
So this is a different CT sping setup? Or is it the same Eibach kit just sold through CT?
Old 09-29-2004, 11:31 AM
Not Asian
phipark's Avatar
So, these won't have the 'rust' problem?
Old 09-29-2004, 11:36 AM
Not Asian
phipark's Avatar
Nevermind, just saw this...http://www.comptechusa.com/store/110135cl.html
Set of 4 lowering springs, slightly firmer than stock.
About 2" lower in front and 1.7" lower in the rear.
Sounds like the Eibach Pro-kit to me.
Sure is a huge difference compared to the other CTs.
Old 09-29-2004, 12:18 PM
ChadT's Avatar
They're regular Eibachs with a Comptech logo. Good springs. Not the same drop as the old Comptechs at all though.
Old 09-29-2004, 12:23 PM
sidemarker's Avatar
so why not just go by the eibach pro kit and save $100?!??!
sidemarker
Old 09-29-2004, 12:53 PM
Not Asian
phipark's Avatar
sidemarker
that is THE question
Old 09-29-2004, 01:57 PM
fuzzy02CLS's Avatar
So I guess CT stopped making their own springs for the CLS then.
Old 09-29-2004, 02:08 PM
ChadT's Avatar
sidemarker
No reason not to. I got mine for free in exchange for my old rusty Comptech springs.
Old 09-29-2004, 03:45 PM
an adult perspective
Six Shifter's Avatar
well, let's be honest ... Comptech replaced our $299 Comptech (Betts) springs with $199 - $238 Comptech (Eibach) springs because of customer concern over the rusting issue. If you haven't decided on whether your going to go with a full Coilover (Tein) or the spring/Koni (or Tokico) combo, than you'd be foolish to purchase these Eibach springs thru Comptech and have the pleasure of knowing that you've paid at least a 25% markup over the TireRack price for the Eibach's.
Old 09-29-2004, 09:24 PM
Blown is Best
Allout's Avatar
I think they are a more of a slate or charcoal grey color as compared to Black.
Old 09-29-2004, 09:31 PM
Blown is Best
Allout's Avatar
What I mean by that is Comptech's new version of spring. The Comptech/Eibach spring that they recently started selling as compared to their older Silver springs manufactured by Betts Spring Co.
Old 09-29-2004, 09:33 PM
Blown is Best
Allout's Avatar
They're there. These springs just use clear plastic tubing for the isolators so they're harder to see in the picture.
Old 09-29-2004, 10:44 PM
Blown is Best
Allout's Avatar
I can't argue with that. I actually ordered these a month ago before it was known that the new versions were OEM'ed for Comptech by Eibach. Since I already had them, I wasn't going to go through the hassle of swapping them out. I'm kind of neutral on the issue.
As a side note, Comptech still has better customer service than Eibach. I had a bad experience with Eibach about 4 years ago and got the run around on a couple of bad items.
1) One was a set of springs for my 300ZX which had the wrong front springs in the set. It took a while to get them to realize that I had the wrong springs before they corrected the mismatched set.
2) I had a bad Eibach Camber kit for my Toyota and they didn't want to deal with it. After a few calls, they finally referred me over to SPC who manufactured the kit for Eibach. SPC took care of the problem without question. That's why I'm a SPC fan use their product over others.
Old 09-30-2004, 07:56 AM
fuzzy02CLS's Avatar
So what happened to all this "engineering" CT did on their springs. They were supposed to be superior because they had specfic spring rates for each corner of the car. Each spring was meant for each corner. Are the Eibach's the same way? Or are they just front & rear. Since they lower the car more now, I'm glad to have my real CT's cause that's lower then what I wanted.
Old 09-30-2004, 02:46 PM
Blown is Best
Allout's Avatar
I don't know if they actually had engineered a specific spring for each corner. It was just due to their quality test of the spring rate that we were able to determine the best spring for left and right. I think all springs have a variation. Comptech was able to take advantage of the variance.
Eibach does not do this individual testing so there's no way to determine which one should be left vs right. I'm sure if we measured the Eibach's, we could do the same. As it stands now, only front and rear springs.
Old 09-30-2004, 11:11 PM
TQ > MPG
Joe5.0's Avatar
How do you like the Illumina's? I am still pondering between the Illumina's or the HP's. I dont know if the adjustability is worth an extra $150.
Old 10-01-2004, 02:21 AM
Blown is Best
Allout's Avatar
I like the adjustables quite a bit. I like running my settings a bit stiffer than the HP's and I like the handling. So far, I'm still trying to get the right balance in this car. If you don't mind spending a bit more, they're worth it to give you the flexibility to tune the suspension. If you're not into that and just want a good riding strut, the HP's are fine. I ran the HP's in my 300ZX for 100K miles and they functioned fine.
If I didn't have a hookup on the Illuminas, I'd be all over the Koni adjustables in the Group Buy that Speed Distributors is doing in the Black Market right now. You may want to consider them at $550.
Old 10-01-2004, 03:36 AM
TQ > MPG
Joe5.0's Avatar
I can get Illumina's for almost $200 less than that, and I have read that Koni yellows are even firmer than Illumina's. I am more worried about a too firm ride than race track ready handling. Have you tried the shocks at the sfter settings? Are they floaty at all?
Old 10-01-2004, 08:04 AM
ChadT's Avatar
Konis are real bumpy over small pavement irregularities but have great control on quick turns and such. I had Bilstiens on another car and they are made to absorb small impacts and control bigger motions. Would probably be the perfect shock for this car. I like my Konis overall but they atre a little stiff.
Old 10-01-2004, 03:03 PM
Blown is Best
Allout's Avatar
I've got mine set at #4 right now (1 being the softest and 5 being the stiffest) It does give a pretty firm ride and not floaty at all. If you can get Illuminas at that price, I would definitely do so. You'll enjoy the ability to set it to your taste and the ability to change it based on your mood. I've also had them set as low as #2 and the ride is very comfortable - still not floaty.
Old 10-01-2004, 03:04 PM
Blown is Best
Allout's Avatar
What setting are you running on front and rear?
Quick Reply: New CT Springs are in
