My shock fell through my damper fork and slammed into the driveshaft!
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
i was driving this morning to work when all of a sudden a hear a REALY loud BOOM from my driver side wheel, I thought I hit a pot hole and deffinatly bent a rim it was soo loud. SO i pulled oved right away to see the damage.
My tire and rim looked fine but i noticed OIL in the inside of my rim and all over in the wheel well, so i walked back to see if I hit a bottle of something that exploded. There was no pothole or no bottle so i get in my car and finish drivingv to work. I hear rubbing the whole drive, when I get to work (I Work at a DLR) i had one of the master techs take a quick look under the car.
The shock came through the damper fork and is laying on the driveshaft , It hit that rubber boot with all the grease in it, so the shock exploded and that rubber boot exploded. He thinks that the metel tab that holds the shock in the damper for snapped off, but they want to put it on a lift to make sure.
So this is MY B@G shock that is under LIFETIME warrenty and the metal tab snapped after 4-5 montha all-ready!
I want to put the car on the lift B4 I start making calls to Excelarate and B@G.
This REALLY SUX I hope the shock slamming into the driveshaft didnt damage anything else cuz it did make a REALLY LOUD bang when it happen.
Now I also have no way to and from work!
TellinItLikeItIsSince1/06
wow, sorry to hear man!
what year, how many miles did you have? i have never heard of this happening...was your car in any known accidents prior to this accident or prior to your purchase of the car?
Whats up with RDX owners?
That does suck. So your axles boot tore as well? You can either repack a new boot or get new axles. Id go with new axles, they are cheap at AutoZone with a lifetime warranty.
B A N N E D
My car is a 2001 with 169k miles... I just put these shocks in less the 3000 miles ago..
I am 80% possitive that metal tap that holds the shocks on the dampening fork snapped off.. I will not know till later but will take pics and update u guys when they have time to put it on a lift.. I work for a GM dlr so there service dept is very busy! The screw is still in the dampining fork and the fork does not look cracked or anything so im sure it was the shock that was defected, the metel tab should not break after 4 months!
How much do axels cost about? do I have to replace both at once or can I just replace the one the shock fell on!
B A N N E D
I was in a couple of accedents 6-7 years ago, but only cosmetic.
I never heard of this and when the techs took a quick look at it they said the part was faulty, The ONLY way something like that can happen is bad welds on a faulty part, BUT i wanna put it on a lift and have the master tech look at it B4 i call some people to get a new shock under this LIFETIME warrenty!
If they faulty part failing caused anouther part to fail would B@G be resposible for it?
Yes, they would. Whether or not they will cover it though is another story.
It sounds like a design flaw. Most struts Ive used have a tapered end on the strut body, so it cant really slide past the stops on the fork. It sounds like the B@G struts are the same diameter, and rely heavily on a thin piece of metal to support it. Ive never seen the B@G struts, so this is just what it seems like to me.
I'd reccomend swaping out both axles at the same time, thats just me though.
B A N N E D
b@G was pretty cool about the situation..They SAY it never happen b4 and I was the first case they saw this happen to..But who is gonna say your the 3 person this week with a shock falling through your fork..?? They are 2nd day shipping it to me and they shipped it right after i sent them pics , thank goodness cuz i didnt feel like taking the shock out and sending to them and waiting for a replacement!!
I got a tracking # for 2nd day air about a hour after sending the pics so I deff would give them a A+ for customer service!
B A N N E D
It just looks like the metal band that holds the boot broke off.
SO i am gonna pump some grease into the boot snap a new metal band around it and hope for the best!
I guess I will not know untill I take the shock out and put the new one in!
When it hit it was LOUD so I am praying nuttin else went wrong!
B A N N E D
MY coil went bad and i was without my car for 3-4 days and now i am without my car for 3 days! This really is the worste month of the whole 9 years of my car!
B A N N E D
The owner of the DLR I work at used to own 3 DLR's rt23 pompton plains, route 46 towtwa and rt17 ramsey in NJ.. I used to be top dog at the 23 location and it was the best the shop hours where till 6 pm but they left the shop open so after 6 i would drive my car in and put it on a lift , alot of the tech would stay and have happy hour after 6 so I would use there tools and they would look over my work or even do the work for a case or two!
Now in the new loc 46 they close ALL doors to the shop at 6 so I have no access to the lifts after hours, but they would do little things for me here and there but this is gonna cost me 1 hour labor, thank god they charge employees 35/hour for labor so after taxes its gonna cost me about $42 cuz it should not take longer then 1 hour to fill and clamp the boot and swap springs and install new shock!
They put my option pulley in for $42 so its no too bad but its not great like I had it where I had access to all the snap on tools and lifts and all the drunk knowledge of cars!
I do have a honda expert here so he is pretty good with doing all this stuff to me car, rather do it mysel;f though and KNOW its done RIGHT!
Received 1,080 Likes
I don't know, It does not look like it..
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
B A N N E D
I am gonna fix it up and hope the axel is all good , I should get to it tommorrow that when my shock is suppose to be here according to ups shipping!
B A N N E D
It was deffinatly a faulty product. None of the techs at my shop nor the guy at B@G seen anything like this before. It was prob welded on a friday at 4:45 pm or monday a 8:00 AM after a hangover!
I sent a few photos to the B@G tech so they can foward them to the people that weld the shocks so they can improve there products so it does not happen to anyone else!
It looks like the tube caved in where the metal tab was welded. You can see the oval indentation where the paint wasn't scraped off, then as it was pushed up, it caved in the tube until it broke off and wedged itself higher and appears to have punctured the tube. Either the tube wasn't strong enough to support the weight of the car on the tab or the bolt was loose and just hammered itself to destruction.
Check the welds of the others and compare them with the new one. Can you take close up pic of the broken welded area?
B A N N E D
B A N N E D
So My transmission on my car went out 2 times, does that mean I will never buy anouther honda/acura product..No they had great service both times it happen and treated me well, same here there product failed BUT they where really cool and sent out a replacement ASAP , 1 hour after I sent then a photo and 2 hours after it happen I had a tracking # for 2nd day AIR that is great customer service.. I work with people all day and the product I sell is not the greatest but people keep comming back becuz I treat them right and that is the most important thing for me. It did not cause any damage to my car, my car is back on the road and driving GREAT again and handling GREAT again. Any Idiot can mess up a weld, and they never saw this b4 with any of there shocks.. If this happens again then that is a different story, even w/my car tranny went out not 1 time but 2 times and I will still buy anouther Acura, next time a RL though.
B A N N E D
And all the components have a LIFETIME warrenty so its not like I paid for the part or the shipping!
dont be mad
dont be mad
and they both come manual, which i would get over the auto any day. Eitherway, i dont know how fast this guy was going when this happened, hopefully his replacement ones dont blow up while hes on the highway, suspension is something u dont cheap out on
B A N N E D
I also picked it up becouse the drop is perfect for where I drive and didnt not need a camber kit my alignment was perfect after the instalation and the car handles GREAT and the ride feels stock . A few other people bought the same suspention for there cars and all are 100% happy with there product.
Any company can make a product with 1 bad weld do u think a comptech product never had a bad weld?
Before u go saing I cheaped out on my suspention do some research!
B A N N E D
Ticking / clicking noise coming from behind sngine when idleing..
I did a search and I see that is is a common problem.
I was checking my oil, tranny fluid, and that my actulator was working and kept hearing this tick/clicking noise comming from behind the engine.
At first (B4 i strarted searching the forum) I thought my valves but then when listening closer it was not comming from where the valves are located. The ticking / clicking is prob my purge control solenoid.
My question is did it always do this, I never really noticed it b4 today and i do mess under the hood alot I think i would have noticed it.
DO the purge control solenoid only start to tick when it gets older if I buy a new purge control solenoid will the ticking stop.
The ticking is a rythem a fasted tick but when the rpms go up u dont hear it anymore and when they come back down to idle it take a few seconds to start up again.
Is there a DIY on installing a new purge control solenoid and is it easy..??
BTW from what I explained do u guys think the problem is the purge control solenoid?
3.5 psi
I put a new purge solenoid in recently. You can hear the ticking and if you put your finger on it, you can actually feel the ticking. Just need a pair of needle nose to get the hoses off and put the new one back on. Super easy. And there may be a DIY somewhere...maybe the TL side.
B A N N E D
